Old 10-13-2004, 09:56   #1
Remco
Remco's Avatar
Member: 334
Communucation error
I have a problem with Blazer when i want to unlock a c1200.
The box worked fine but now i have always communucation error.
I tryed al versions and use XP and Win 98sec but always the communucation error.
When i power up phone with the soft phone is on for 2 sec than off.
I opened the cable and connector to check the wires but seems ok.
What else can i do to check what the problem is?
Old 10-13-2004, 11:14   #2
Raskal
Raskal's Avatar
Member: 563
Sonork: 100.11111
Maybe your cable is damaged some how, as you said box work okay before. to make sure it is a cable problem, it is the best to try make another phone and to check it.
Old 10-13-2004, 15:09   #3
Remco
Remco's Avatar
Member: 334
I test with cable c and now the box works with a phone.
I check my cable,the box is working.
I post result here.
Old 10-14-2004, 15:15   #4
Remco
Remco's Avatar
Member: 334
The problem is in the rj45 connector in the box.
I change the connector and now all is working fine.
Old 10-24-2004, 05:36   #5
Raskal
Raskal's Avatar
Member: 563
Sonork: 100.11111
Remco, we talked few days ago about the file wich u uploaded, this file is corrupt, please read again flash 1 and 2 and upload again.
Thanks and best regards,
Raskal
Old 10-24-2004, 16:33   #6
Remco
Remco's Avatar
Member: 334
I upload again and wait for your answer.
Old 10-28-2004, 20:47   #7
ARC
ARC's Avatar
Member: 5019
Sonork: 100.110196
I Ordered U8110 cable, the box can identify it as cable F U8110 series,
but when i connect it to phone, i always get Communication Error!.
I tried connection without battery, same problem.
I also checked the schematic of cable connector, all is ok!
any help?
Old 11-01-2004, 09:33   #8
Remco
Remco's Avatar
Member: 334
Raskal i tried now ver 5.6 and soft still ask for update for a LG-510W.
Is this a special version or is my cable and box not good.
Please advise me what to do.
Old 11-01-2004, 10:29   #9
cpu486
Member: 3918
any help?
I have same problem
I even made a new cable by shematic on blazer site, changed connector and again "communication error".
Any solution, please?
Page generated in 0.10567 seconds with 6 queries
