Go Back   GSM-Forum > GSM Mobile Brands -Software Area- > Sagem > Wallpaper, Applications, RingTones, etc
Wallpaper, Applications, RingTones, etc Nothing here for Unlocking Sagem Phones or Flashing, this section for RingTones, Wallpapers, PhoneBook matters and Downloadable Applications.
Old 11-05-2004, 18:08   #1
fen_tzu
Member: 80462
Themes for SX1
I see that many themes for SX1, but when I download and try to aplicate
it Can't (remebering that only for 6600 or 7610)
I want to ask To Master, how to aplicate?
what should I do???
anyone have photo acute that compatibel for SX1??
Thanks for reply fen_tzu@yahoo.com
Old 11-05-2004, 20:50   #2
3aTmr
3aTmr's Avatar
Member: 26670
SX1 doesn't support theme changing...
Old 11-06-2004, 23:58   #3
bimbo28
Member: 53763
It doesn't, but take a look at this thread and see randomi's posts...
http://www.club-siemens.net/forum/vi....php?tid=42472
If anybody knows how to do this (modifying firmware,etc), can you please share your knowledge to us
Old 11-07-2004, 00:40   #4
TeXeT2
Member: 87977
http://oslik.ru/phpBB2/viewtopic.php?p=50193#50193
You can translate world.altavista.com
Old 11-07-2004, 15:58   #5
dinocol88
Member: 76866
do they have fw15 working with themes? cud u pls post link?
Old 11-07-2004, 19:57   #6
Drug_Store
Super Moderator
Drug_Store's Avatar
Member: 15312
Sonork: 100.1576041
Humm... it´s seems simple.
Only need to change firmware instructions of Z: to E:
First copy EdiPic.MBM from z:\system\data\ to MMC.
With Winhex, open 07102004-K1_SiemensvA114_signed.exe (firmware), edit primary memory on unicode mode, look for z:\.system\.data\ that should be Z.:.\.S.y.s.t.e.m.\.D.a.t.a.\.E.d.i.P.i.c...m.b.m, change it to E.:.\.S.y.s.t.e.m.\.D.a.t.a.\.E.d.i.P.i.c...m.b.m, save and flash... seem very simple.
Harder seems the "theme builting"...
Transcribed from oslik.ru:
http://spirit.net.ru/pics/bconv.gif
"Is discovered Bitmap Convertor and we select "Decompille MBM" (in the figure it is designated as 5 point). We search for file EidPic.mbm and harvest to it. In the folder with file EidPic.mbm you uvidete other files EidPic0.bmp EidPic1.bmp EidPic2.bmp EidPic3.bmp EidPic4.bmp. It is discovered by any of these it is file in Adobe Photoshop. and we edit it as you want.
But if you want to create valuable theme that read further. We create two files by the size of y"8khyeya and y"'kh'8, the first file part which will stand on skrinservere, the second file this is upper part. We go in it inet and we search for themes for Nokia 6600 or 7610. We copy the picture, which we videm on the site, chtoto type stripped picture from the screen. We put picture in our grafficheskiy editor. And we further drive on everything according to the sizes. Upper part into size BMP, and lower in GIF. Further we start Bitmap Convertor and we select "Add Bitmap" (in the figure it is designated as 1 point), we select there EidPic0.bmp EidPic1.bmp EidPic2.bmp EidPic3.bmp EidPic4.bmp. We place galochku near "24 bits" (in the figure it is designated as 6 point) and we harvest "Create MBM"(na figure it is designated as 4 point).
We push in into file EidPic.mbm in e:\.systam\.data. It is reloaded and in the honeycomb we go in the "menu" = > of "tuning" = > "telephone" = > the "standby mode" = > "background picture" = > "yes" and we select your skrinserver, which approaches your theme.
This is what came out in me. "
I personally don´t have the time needed to try this, but when have a time, will do it
Old 11-08-2004, 15:25   #7
SkizZO
SkizZO's Avatar
Member: 70855
...i have fullscreen wallpapers and sis theme installed made by me and neodigital people.....
An user has made a program that put pics in mbm fileS and create the sis installation file with an UNIC UID (ordered from symbian developer)
it's simple
Old 11-08-2004, 21:56   #8
3aTmr
3aTmr's Avatar
Member: 26670
share it woth other SkizZO
Old 11-09-2004, 00:21   #9
SkizZO
SkizZO's Avatar
Member: 70855
A) Your firmware MUST BE PATCHED (i use fw12 with stefanoG patch for fullscreen wallpaper & increase audio volume)
B) If you uninstall the theme make you sure, before reboot, to copy file eidpic.mbm to c:\system\data from e:\system\data
C) Save the sis file in a dir that no contains spaces & writing the extension
es: c:\name.sis --> oK
D) You can create a new theme and reinstall it (overwriting old theme), the UID assigned is developed by "symbian developer", then it's assigned ONLY for this sw
EnJoY! W iTaLiA CiaO !
File Type: rar WallPapizer_By_matH(Neodigital).part1.rar (683.7 KB, 303 views)
File Type: rar WallPapizer_By_matH(Neodigital).part2.rar (527.6 KB, 219 views)
Old 11-09-2004, 14:32   #10
dinocol88
Member: 76866
anyone here could tell us where to get the other patches? or pls post instructions...
Old 11-09-2004, 18:18   #11
3aTmr
3aTmr's Avatar
Member: 26670
what would happen if I would install .sis application made by wallpapizer and I don't have patched fw?
p.s. where to find those patches?
Thanks
Old 11-09-2004, 18:28   #12
fen_tzu
Member: 80462
I use FW 15, and I have install the sis
but, only wallpaper change (not full screen).
Is there anyone can help???
how to patch??
Old 11-09-2004, 19:38   #13
3aTmr
3aTmr's Avatar
Member: 26670
patching is easy, but only we need the right pathes
Old 11-09-2004, 20:56   #14
BrollY
Member: 82358
if u patch the fw u loose ur warrenty????
Old 11-10-2004, 01:56   #15
SkizZO
SkizZO's Avatar
Member: 70855
go to www.neodigital.it and apply the patch vith vklay to SX1_International-uk-de-it_12_0001.exe , then copy from z:\system\data eidpic.mbm to c:\system\data (or install a sis theme), now you can update your phone
(if after update the system don't find eidpic.mbm, it doesn't start... then copy it before or make a format and the file will be copied)
..i hope another language can be patched but not another fw version!!! ONLY 12
will be "trasferred" eidbic.mbm from z: to c:\data\system (the system look for this file in another dir.. c:\system\data wich is editable)
Then we can owerwrite eidpic.mbm and + wallpaper.mbm = fullscreen wallpaper
IF YOUR PHONE IS PATCHED
If you delete eidpic.mbm (or uninstall sis files), MAKE you sure to have a copy of eidpic.mbm in c:\system\data before reboot, if not the cell doesn't start (howewer formatting c:\ the file will be opied again)
FOR NON PATCHED PHONES
The sis installer copy 2 files to c:\system\data:
- by default background.mbm is stored in c:\sys\data, then the image will be displayed (normal wallpaper)
- by default eidpic.mbm is stored in z:\sys\data, then we cannot edit it... the patch change drive to store image and sis installer overwrite it
....if you install a sis themes change lower background because the upper is in z:\sys\data, not in c:\sys\data (<-- patch) and we not see it...
Uninstall sis theme and all is ok!
:::::::::::::::::::::::::ENJOY:::::::::::::::::::: :::::::::::::::::::
[IMG] code is Off
Page generated in 0.13077 seconds with 7 queries
