Siemens-Benq RingTones and WallPapers NO Unlocking or Flashing threads here, this section for RingTones, Wall Papers, Games and other Staff. |
11-11-2004, 12:45 | #2 (permalink) |
Freak Poster Join Date: Jun 2004
Member: 70990 Status: Offline Thanks Meter: 1 | (first of all: all siemens mobiles work with siemens firmware (software)!) ...I think you want to remove your vodafone software branding (Log-animation etc.) - correct? If you want to do this, you need a data cable and data exchange software (DES) if you don't have, you can download at siemens-mobile.com. Connect your mobile, open DES, make all folders visible (in windows menu -> folder options), now there is a light folder called "customization" - open it, now there must be a folder "operator"...if you delete this one, your vodafone branding is killed. I suggest you to make a backup of that folder "operator" so you can restore it if required - example for warranty. Good luck genetic1 |
11-11-2004, 13:01 | #3 (permalink) |
Junior Member Join Date: Nov 2004 Age: 54
Member: 90067 Status: Offline Thanks Meter: 0 | Nope, i want to put up the whole original cx65 fw, because the patches are on another address. For example: enable dev. menu cx65 fw25 1336914: 04 08 on my phone (cxv65 fw25) the address is 1334a54. So if i haven't got the piece of codes i can't find this function. Other thing, the vodafone software always appears later than original cx65 fw. |
11-11-2004, 20:50 | #5 (permalink) |
Moderator Join Date: Jun 1999 Location: Serbia Age: 48
Member: 163 Status: Offline Thanks Meter: 7,786 | i have here 2 pc. of cv65 ... solution that might work (i'll test it tomorrow) - read full flash from c65 - patch flash with patcher - write into cv65 (MAKE BACKUP BEFORE!!!) - make map, upload to phone with eeTools that should work ... but not tested yet please test and post result should be the same for all models b.r. ALexandar. |
11-16-2004, 22:38 | #7 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,786 | just to confirm that mentioned operation works 100% (patch bootcore to both phones - ie: c65 and cv65) read fullflash from both phones patch c65 fullflash with flash patcher from Nike write it into cv65 make map upload with eeprom tools all works 100% just one little problem ... since the flasher CAN'T write bootcore to phone (c65 bootcore to cv65 bootcore) SWUP for c65 cant work anymore (always says - SW UPDATE DENIED BY MOBILE) so ... before reading flash from (for example) c65 upgrade it to v25 with latest swup and then read ... so you will have latest version in your cv65 ... above procedure is tested with two cv65 phones ... both were succesfully converted to c65 v25 i think it should work with ALL x65 phones .... if anyone knows how to write bootcore to phone ... let me know. b.r. Alexandar. |
11-20-2004, 19:08 | #10 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,786 | i dong get it ... what else do you need ? all that you need to know is already written in previous post. - take one working Cx65 ... update it with SWUP to latest version (v25) - patch the bootcore with java patcher - read the full flash with x65 flash reader/writer - do the same (except update) on Cx6V (vodafone phone) - patch the readed flash with flash patcher by Nike, to enable EE access - write that patched flash from Cx65 to Cx6V - make .map file and with eeprom tools upload to Cx6V phone thats all ... after that you have PURE Cx65 phone read another topic for procedure of patching boot, patching flash and making map, etc. b.r. Alexandar. |
01-20-2005, 17:36 | #11 (permalink) | |
Member: 90067 Status: Offline Thanks Meter: 0 | Quote:
So. I wrote cx65 fubu into cxv65. It asked overwrite bootcore and EEFULL. Of course i skipped the bootcore, but what about EEFULL? Can i overwrite? Anyway I can't get ID with getcode software, so i can't make map. Any idea? | |
01-23-2005, 15:31 | #12 (permalink) | |
Insane Poster Join Date: Dec 2004 Location: _-°TUNISIA°-_ Age: 42
Member: 98353 Status: Offline Thanks Meter: 1 | Quote:
Ok can do that - patch the bootcore with java patcher Ok did that - read the full flash with x65 flash reader/writer Ok can do that - do the same (except update) on Cx6V (vodafone phone) Ok can do that - patch the readed flash with flash patcher by Nike, to enable EE access flash patcher by Nike ok i found this at ftp://213.96.161.186 but why to enable EE access I thought it wos only required for unlock !! ???? - write that patched flash from Cx65 to Cx6V Ok can do that - make .map file and with eeprom tools upload to Cx6V phone What is this for ?? how to make map ?? what happen if i don't do that, why not just rewrite the eeprom (map is in the eeprom aahh ? and now i just remembered eeprom is in full flash eehh !!!..................) !! Too many question eeh sory but i really want to know evrything... Thank u very match... Last edited by lowave1; 01-24-2005 at 17:58. | |
01-23-2005, 21:10 | #13 (permalink) | |
01-24-2005, 13:23 | #14 (permalink) | |
are all C65 hve same map ?? i'm talkin about C65 not C6V neither C6... cos i hav a zip containing all c65 map found on a russian site ... can provide u with standard C65 map if u need ... | |
01-24-2005, 16:56 | #15 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Greece Age: 47
Member: 26279 Status: Offline Thanks Meter: 274 | try to use sst unlock and repair function. if you just flex your phone with CX65 FFS init then vodafone menu will completely remove except the icons on menu. |
i want to change my nick and avatar .. i cant use my old nick | ..::iboc@N::.. | Board, Server and Login Problems/Support | 5 | 02-23-2010 20:55 |
I want to unlock my VODAFONE 125 | gsm-unlocking | Phone Unlocking Codes & Maps | 0 | 03-03-2009 22:01 |
I Want To Change My Reliance Handset To Tata Indicom Network ? | ARUNCREATIONS | Various CDMA/TDMA Cell Phones | 3 | 11-28-2005 15:57 |
plz i want to change my nick name plz Winner58 | Ramiz | Board, Server and Login Problems/Support | 5 | 01-05-2005 11:04 |
I want to change my sms-tune on my 3310 | Obi1_be | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-05-2001 02:05 |
