Old 02-21-2005, 22:22   #1 (permalink)
juht's Avatar
Member: 6208
Thanks Meter: 12
6100/3100 Flash IC
Hello. Please can someone tell me, what flash can i use if i dont have an original K5U64418TM SEC 247.
Can i use flash from 6310 (i640W18TD)?
Or flash from 8310 ( iF640W18T)?
Or flash from 7210 ( K8S64158TM)?
Or flash from Ngage ( N643GT7MI)?
Problem was, the phone losed the network. First i flashed it with new firmware, no success. Then I reheated the PCB, all parts, and phone was dead. I tried to flash it, twiser said :UPP ok, boot also ok, but after flash erase, in 10% flashing error. With Griffin also same problem, flash erase ok, but in first 10% error(connection lost ors). I think i must change the flash ic, cause first, when the problem with network begin, phone also freezed and rebooted. Or what should be the solution.
Any help will be great.
Old 02-21-2005, 23:13   #2 (permalink)
Registered User
Member: 1815
Thanks Meter: 3
first step!
try to reball the flash chip and flash the phone again!
Tom
Old 02-22-2005, 07:57   #3 (permalink)
juht's Avatar
Member: 6208
Thanks Meter: 12
Ok. I try that. But its more comfortable to put the new flash chip to the phone. I may be killed CPU with overheat? But then phone i think were totally dead - no communication with twister(it says UPP OK) and no start to flash erase.
Problem is, those original flash ic's are out of stock from my supplyer.
Pls, help
Old 02-22-2005, 12:19   #4 (permalink)
juht's Avatar
Member: 6208
Thanks Meter: 12
Solution to fix such problem(i guess not only for 6100/3100, also other dct-4) is change UPP.
Twister said, before i changed UPP:
1st Boot Ok, DCT4, UPP: 1120
FlId Aliasing with: 00EC22F0
Fl0: 0x01000000-0x017FFFFF,00EC22F2,Sam K5U64418TM
Algorithm: u_amd.fia
Algorithm Ok, MSID: 84DF1EAFB0AC61DAAFD3167073
Decoded MSID: 516EBAE9-00C3E53C-A9000000
Encoded FAID: 983BA2C1-41083ED7-995FE4AB
Area1: 0x01000000-0x0100FFFF Erased, Time: 0:00
Area2: 0x01010000-0x0154FFFF Erased, Time: 0:43
Area3: 0x01680000-0x017EFFFF Erased, Time: 0:12
Area4: 0x01EB0000-0x01FEFFFF Out of Chip Bounds
Write Error: hDat 14, at: 0x01040000:08
Process Failed, Repowering Mobile
There is no problem with flash and UEM. Good luck. I got phone worked.
Old UPP was 4370931 and i canged to 4370873. working OK.
But i have still question - what kind flash types i can use in 3100/6100?
Old 02-22-2005, 14:03   #5 (permalink)
Member: 9763
Sonork: 100.1655983
Thanks Meter: 2
yes juht u asked a question I think a lot of us in the forum seeking an answer for it , so please guyes help .
Regards
Laser
Old 02-22-2005, 19:40   #6 (permalink)
Member: 63385
Thanks Meter: 3
Check which flash version u are using... Try to flash with higher version 'coz i had d same problem with 61/3100 before and just solve it flashing with higher version. Check i the support site for the flash files.
Chill!
merulez29
Old 02-22-2005, 20:11   #7 (permalink)
Alim Hape's Avatar
Member: 43548
Thanks Meter: 2,192
Use K8S64158TM from 7210
Old 02-23-2005, 06:40   #8 (permalink)
juht's Avatar
Member: 6208
Thanks Meter: 12
Chill!
merulez29
Thanks for replay, but this doesn't helped me. Phone had sw v 5.54, upgraded to 5.91. The signal were a little bit better. But phones losed network sometimes. Then i tought to reheat the PCB. Strange, why UPP died....first thought, when phone was dead, that flash ic is dead...then UEM...and finally, when twister gave same error after UEM and flash change, i decided to change UPP and it worked. I'm not sayin, that this network problem was in UPP, or in flash or in UEM IC, but right now the phone works. Let's see, what brings the future.
To reball the flash is real pain in my ***, thats why i thought to put the new, reballed flash ic, to the phone. Original IC was out of stock of my supplier, and my toughts were simple - what flash IC can i use.
I hope you i-mobile are right. I try this next time. I let you all guys know my experiens too. It were very helpful, if somebody wrote here the same - clearly what IC exactly and what phone
No hard feelings
Old 02-23-2005, 08:47   #9 (permalink)
yoya's Avatar
Member: 80255
Thanks Meter: 15
Use flash ic from 7250i, 3200 3300 (combo flash- whit ram inside) can use flash from 7210 who gatno RAM on board. Network problem cause cpu (v826-4370931) and uem (write asic2 rpl), if change flash ic write good PM (if bad is low signal or cant find network. When chaking network use manual search if searching long time uem posibile is good just write new PM.
Best gegards
Old 05-12-2005, 05:49   #10 (permalink)
hooi76's Avatar
Member: 7741
Thanks Meter: 111
i have problem with the network problem only on 1800 mhz that works perfect, but no network on 900mhz.
Old 05-12-2005, 14:13   #11 (permalink)
hooi76's Avatar
Member: 7741
Thanks Meter: 111
i already change PA, Antenna Switch, CPU, UEM still no network. before changing the parts, the phone have pcn fluctuating signals. But Now the phone have signal bars (but there is no fluctuating signal from the phone and then in 2 seconds the phone totally have no network on both gsm and pcn). Towmorrow i will change the flash chip + UEM and test for results and write the rpl. Hope tomorrow the phone will back to network on both pcn and gsm.
Old 06-16-2005, 22:34   #12 (permalink)
Member: 72894
Thanks Meter: 23
Have u check the Crystal Oscillator 26 Mhz before? or Helga/Mjolner.
Old 06-17-2005, 19:03   #13 (permalink)
hooi76's Avatar
Member: 7741
Thanks Meter: 111
but the phone is not working on 900mhz, it works well in 1800 mhz. i don't think it's the 26 mhz crystal
is 3100 flash ic working in 6100 please help me shivam4you Nokia Hardware & Hardware Repair 10 12-05-2008 10:12
Nokia 3100 flash Ic changing mobilelink Nokia Hardware & Hardware Repair 11 08-12-2007 08:15
6100 Flash ic info needed Anno Nokia Hardware & Hardware Repair 3 10-01-2004 04:46
Nokia 6100 flash IC compatibles ...?? Medz Nokia Hardware & Hardware Repair 0 03-27-2004 18:46
Page generated in 0.23983 seconds with 9 queries
