Go Back   GSM-Forum > GSM Mobile Brands -Software Area- > Various
Various AEG, Bosch/Dancall, Toshiba, Vitel, Maxon, Sendo .... and any other Phone which can't find any serving section for it......
Old 02-28-2005, 18:53   #1
dzunlocker
dzunlocker's Avatar
Member: 79640
Thumbs up unlock TS21i without flashing and testpoin
Hi all,
Ill present here new-old solution for ts21i. No need tespoint, no phone flashing.
The old solution consist to frash phone by making testpoint. U ll find it in old posts this forumprocedure here :
But flashing and tespoint are dansgerous. And flash R/W process is too long.
Now with this new method, we can unlock phone in less 1mn.
A - Toshiba ts21i cable :
B - Toshiba R/W flash soft TTPCOM flash 430
(Search soft and pinouts in this forum)
1- Connect cable to powered-off phone without making tespoit
2- Launch soft and configure it :
a - Choose com port baud rate 57600 and master cloc 1843200
b – Click file browse button and shoose backup directory and name in
this example
c – Click on specify range adresse and set :
Start to 0x007FE000 and End to 0x007FE010
d - Click on start, when soft says "Power On/rested target" press phone's power buttons and hold it down until reading process terminate.
3- Now open backup file with a text or hex editor. U will find CODE in plain text chars from position 8 to 15.
- Now power on phone with an unnaccpeted simcard and and when asked, introduce the code.
- Phone says "switch off phone". Switch off phone and on again. Now phone is un locked.
Old 02-28-2005, 19:02   #2
zaskar
zaskar's Avatar
Member: 60746
thx
i'll try with next one...
Old 04-03-2005, 22:05   #3
weirdlock
Member: 68326
Nobody has any results on this yet?
Old 04-04-2005, 23:53   #4
TheMasterGSM
TheMasterGSM's Avatar
Member: 73387
Wink
I never used Testpoint
br
Old 04-06-2005, 09:31   #5
Murat Bekar
Murat Bekar's Avatar
Member: 2088
solution working. I tested yesterday.
Regards
Old 04-21-2005, 13:53   #6
atlasgsm
atlasgsm's Avatar
Member: 6420
i tested and it work only enter spck and all is ok
but must do test point
br
Old 04-29-2005, 22:51   #7
matrix05300
Member: 49494
Originally Posted by dzunlocker
Hi all,
this example
A smart Hack, Thanks man
this change little bit from a rediculous "give me one click-and-go way"
BR,
Old 05-26-2005, 10:26   #8
prabue
Member: 17720
what is the pinout - need external power or not
it is possible to convert t205 cable for toshiba
test point need or not
Old 05-26-2005, 10:41   #9
Bigbrothers2000
Bigbrothers2000's Avatar
Member: 487
yes is possible you can use it but must convert first
Old 05-26-2005, 17:15   #10
prabue
Member: 17720
what is the pinout , need external power or not
Old 05-26-2005, 22:23   #11
GSMSERVE
GSMSERVE's Avatar
Member: 80990
Sonork: 100.1583974
So long and also dangerous... don't you find it so??
BR weld bladi
simplex
Old 05-27-2005, 03:18   #12
BouRRi_GSM
BouRRi_GSM's Avatar
Member: 111457
Pinout TS21i
Tested
Old 05-27-2005, 12:09   #13
souzz
Member: 148491
I searched through the forum and can't find the
"Toshiba R/W flash soft TTPCOM flash 430"
Please, can anyone give me the link?
Thanks!
Old 05-28-2005, 15:33   #14
equinoks
equinoks's Avatar
Member: 21508
Thanks!
you can take it from HERE!
BR.
Old 05-30-2005, 11:34   #15
souzz
Member: 148491
BR.
Thanks a lot.
To All:
Some ideas for changing the language packs in TS21i firmware?
it there exist some info about format of langpack for Toshiba?
i need to add language into firmware.
Page generated in 0.09448 seconds with 7 queries
