| Siemens Hardware Repair Area all about Hardware Repairing you can get if here. |
#16 | |
![]() ![]() ![]() ![]() Join Date: Aug 2004
Member: 79056 Status: Offline Thanks: 0
good work man
but u forgot to make ur pictur with solucion Quote:
ReGarD |
| The Following 3 Users Say Thank You to H@idour For This Useful Post: |
#17 |
Member: 81576 Status: Offline Thanks: 4
#18 |
cx65 mic ways
cx65 mic wayssssssssssssssssssssss
| The Following 5 Users Say Thank You to sevgigsm For This Useful Post: |
#19 |
cx65 speakır ways
cx65 speakır wayssssssssssssssssssss
#20 |
![]() ![]() ![]() Join Date: Dec 2004
Member: 100195 Status: Offline Thanks: 0
M55 charge ways
M55 charge wayssssssssssssssssssssssssss
#21 |
CX65 sim ways
BOMBBBB cx65 sim wayssssss %1000
#22 |
![]() ![]() ![]() ![]() ![]() Join Date: Jul 2004
Member: 71273 Status: Offline Thanks: 2
How about C 55 no signal ? i have change PA, switch antene, RF, Dialog (power Supply) ???
#23 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2002
Member: 18442 Status: Offline Sonork: 111110
SEARCH MANUEL network it find or NEVER found? pls explain
Try search network manuel and it jump agaın menu? İf u find and no found network CPU DAMAGED try and post result
#24 |
PA, switch antene, RF, dialog, cpu change still no signal bar help............
#25 |
Member: 18791 Status: Offline Sonork: 100.1577421
I have 2 psc of c62 low network
I change PA and rest but still same is ther any solution ?? BR |
#26 | |
hi
antenna sivitch |
#27 | |
hi
or 13 mhz kristal change |
#28 |
![]() ![]() ![]() ![]() Join Date: May 2003
Member: 29870 Status: Offline Thanks: 9
I have problem with SL55 display LED.This phone come with charge problem and i changed chargin transistor and now phone charge normally but no led .Thanks for any help.
BR. |
#29 | |
I change it from c35 not work aslo from a2618 not work BR |
#30 | |
![]() ![]() Join Date: Apr 2005
Member: 135968 Status: Offline Thanks: 0
..if you have Phase Peak or Phase RMS error above 5 degrees, then it can be successfull, but not realy. If 26 MHz does not work propperly your phone cant sync to the BS. No Network can be found, but low network doesent match. (Check out with Rhode&Schwarz CMU200 or Wavetec GSM-Tester )But with WinSui or with X-Focus you can change the AFC-Key value for the 26MHz oszillator. I had never low Network becouse the 26MHz oszillator. Try following: Check out different provider-cards (with GSM 900 and such with PCN (GSM1800)) Same problem on both? If not - try RX Path between diplexer and RF-Chip. (you need to Know on witch Network the failure occured, and you need shematics) If yes - try to change the diplexer or the RF IC. If you have booted a complete flashimmage from another phone, it could happend, that you have overwritten the adjusted RF values such as AFC-Key, TX-PWM Key, RX/TX values ect. with wrong values. Every Phone need to be adjusted at production, becouse the hardware has different tolerances. greets |
| The Following User Says Thank You to 424owe For This Useful Post: |
