![]() ![]() ![]() ![]() ![]() Join Date: Apr 2001
Member: 4270 Status: Offline Thanks: 0
NEC E616v cant unlock it says Rx error
HI
i have an E616v that gives me RX error when i try to unlock. i've tried it on 3 different pc's and still the same. on the phone the light turns red and gives me an error message on the A: section the cable im sure is working as i have successfully unlocked atleast 8 different types of 3G nec. can some1 please help reo |
#2 | |
Member: 49495 Status: Offline Sonork: 100.9 & 100.12345
u change u r cable and try again ...... |
#3 | |
![]() ![]() ![]() ![]() ![]() Join Date: Nov 2004
Member: 91799 Status: Offline Thanks: 3
Set COM on OBEX port and speed to 256000. |
hi
i tried setting the com port to that speed but still i get this nagging error plz help reo |
Hi
the exact error that i get on the phone is A: MSG Err Wrt Adr Mx C: plz help reo |
![]() ![]() ![]() ![]() ![]() Join Date: Mar 2004
Member: 57430 Status: Online Thanks: 2
change cable and try again
#7 | |
HI
i have now built 3 cables and all dont work with this phone. im using the 2 different programs, but still nothing plz help reo |
![]() ![]() ![]() Join Date: Nov 2003
Member: 43823 Status: Offline Thanks: 0
reo: OK - if you got new Crazzy update run software for E338 and then unlock, your phone will be unlcoked by COM cable in 5 secondws withtou any problems but IMEi will change
![]() Join Date: Sep 2004
Member: 80949 Status: Offline Thanks: 0
see connector in phone( in nec is very soft)
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2003
Member: 22955 Status: Offline Thanks: 1
Or try it as nec 616(without 'v' ) .
Best Regards! |
![]() ![]() ![]() ![]() Join Date: Feb 2004
Member: 54260 Status: Offline Thanks: 17
nec 616v Rx error
solution.simple reinstall the driver and restart the system
i did it it works perfectly for. |
hi
thanx to every1 for their help i really appreciate it. the problem is solved by Mobileland's suggestion. after selecting E616 instead of E616v the software read and worked. thanx to all. regards reo |
Member: 14684 Status: Offline Thanks: 56
And was your phone a e616 or e616v?
Hi
@SJS well i would think its obvious if u read my thread's subject, and the fact that its quite obvious from my last post, but anyway i have an E616V reo |
