| Various AEG, Bosch/Dancall, Toshiba, Vitel, Maxon, Sendo .... and any other Phone which can't find any serving section for it...... |
![]() ![]() ![]() ![]() Join Date: Oct 2001
Member: 6879 Status: Offline Thanks: 13
how to unlock sendo s220
hello world i have 5 s220 from sendo how to unlock it?/??
I HAVE THE SMART CLIP BUT IT STILL DON WORK MAYBE I DOING SOMETHING BAD
Member: 84155 Status: Offline Thanks: 0
DO NOT connect phone battery to connector.
Use SmartClip power only. Also, if possible, try powering your smartclip using an external power supply instead of a battery. Once you connect the connector on to the phone, and power on your clip, before you try unlocking, just try to power on your sendo. If it is powering on, your connection is OK. Now the unlock procedure. Phone Off Connect the connector Power on the clip. Press the unlock button and IMMEDIATELY press the power button on the Sendo..... any longer than half a second or so and it will not work. Please post back results |
Member: 14551 Status: Offline Thanks: 0
I use smartclip and Anjel , Sendo cable and t191 cable but not work , phone power on
![]() ![]() ![]() ![]() ![]() Join Date: Apr 2003
Member: 25806 Status: Offline Sonork: 100.78148
@doomstyle
Please check Mobile IMEI if they show ?????????? so u Rebuild this in Delok or Multibox. caz smartclip not work if sendo mobile have ????? imei br tahir |
Imei it's ok : I check Delok or Multibox.
Tankyou |
![]() ![]() ![]() ![]() Join Date: Aug 2004
Member: 79640 Status: Offline Thanks: 117
Use smart clip.
Dont use phoen battery. Use smart clip as power supply. Best regards |
I use smart clip as power supply but phone power ON.
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2002
Member: 14741 Status: Offline Thanks: 0
