Member: 15022 Status: Offline Sonork: 100.53452
Due to the limitation of the COM ports to the maximum of 115200 Baud you cannot gain the full speed when you do a download with a ISDN Modem using two B-Channels (128000 Baud). To no longer be limited I did develop the HiSerial.sys driver. HiSerial.sys Driver V1.5 The driver is designed for Windows XP and Windows 2000. Maximum COM port speed is 921600 Baud depending on the computers chipset. Not supported chipsets work with 115200 Baud. Downloads with up to 15,6 kB/sec are possible. With activated modem compression even higher values are possible because the COM port no longer is the bottleneck. Currently the following chipsets are supported: ALi M1543 @ max. 460800 baudALi M1543C @ max. 460800 baud ALi M5133 @ max. 460800 baud ALi M1535 @ max. 460800 baud ALi M1535D @ max. 460800 baud ITE IT8761F @ max. 460800 baud ITE IT8661F @ max. 115200 baud ITE IT8673F @ max. 115200 baud ITE IT8700F @ max. 115200 baud ITE IT8702F @ max. 115200 baud ITE IT8705F @ max. 115200 baud ITE IT8710F @ max. 115200 baud ITE IT8711F @ max. 115200 baud ITE IT8712F @ max. 115200 baud SMSC FDC37B72x @ max. 460800 baud SMSC FDC37B77x @ max. 460800 baud SMSC FDC37M77x @ max. 460800 baud SMSC FDC37B78x @ max. 460800 baud SMSC FDC37B80x @ max. 460800 baud SMSC FDC37M70x @ max. 460800 baud SMSC FDC37C67x @ max. 460800 baud SMSC FDC37C68x @ max. 460800 baud SMSC FDC37C93x @ max. 460800 baud SMSC FDC37C93xAPM @ max. 460800 baud SMSC FDC37C93xFR @ max. 460800 baud SMSC FDC37M60x @ max. 460800 baud SMSC FDC37M61x @ max. 460800 baud SMSC FDC37M81x @ max. 460800 baud SMSC FDC37N958FR @ max. 460800 baud SMSC FDC37N971 @ max. 460800 baud SMSC FDC37N972 @ max. 460800 baud SMSC FDC37C957FR @ max. 460800 baud SMSC LPC47B27x @ max. 460800 baud SMSC LPC47B37x @ max. 460800 baud SMSC LPC47M10x @ max. 460800 baud SMSC LPC47M14x @ max. 460800 baud SMSC LPC47M120 @ max. 460800 baud SMSC LPC47M15x @ max. 460800 baud SMSC LPC47M192 @ max. 460800 baud SMSC LPC47N252 @ max. 460800 baud SMSC LPC47S42x @ max. 460800 baud SMSC LPC47S45x @ max. 460800 baud SMSC LPC47U33x @ max. 460800 baud SMSC LPC47U32x @ max. 460800 baud SMSC FDC37C665IR @ max. 460800 baud SMSC FDC37C666IR @ max. 460800 baud SMSC FDC37C669 @ max. 460800 baud SMSC FDC37C669FR @ max. 460800 baud SMSC FDC37N769 @ max. 460800 baud SMSC FDC37N869 @ max. 460800 baud SMSC FDC37N3869 @ max. 460800 baud SMSC LPC47N227 @ max. 460800 baud SMSC LPC47N267 @ max. 460800 baud SMSC FDC37C665GT @ max. 115200 baud SMSC FDC37C666GT @ max. 115200 baud National Semiconductor PC87108 @ max. 115200 baud (No detection) National Semiconductor PC87109 @ max. 115200 baud (No detection) National Semiconductor PC87303 @ max. 115200 baud National Semiconductor PC87306 @ max. 115200 baud National Semiconductor PC87310 @ max. 115200 baud (No detection) National Semiconductor PC87311A/312 @ max. 115200 baud (No detection) National Semiconductor PC87332VLJ/VLJ-5 @ max. 115200 baud National Semiconductor PC87317 @ max. 921600 baud National Semiconductor PC87334VLJ/VJG @ max. 115200 baud National Semiconductor PC87336 @ max. 115200 baud National Semiconductor PC97317 @ max. 921600 baud VIA VT82C686A/B @ max. 460800 baud Winbond W83627GF-AW @ max. 921600 baud Winbond W83627SF @ max. 921600 baud Winbond W83627F @ max. 921600 baud Winbond W83627HF @ max. 921600 baud Winbond W83697HF @ max. 921600 baud Winbond W83697SF @ max. 921600 baud Winbond W83877ATF @ max. 921600 baud Winbond W83877F @ max. 115200 baud Winbond W83877TF @ max. 921600 baud Winbond W83977AF @ max. 921600 baud Winbond W83977ATF @ max. 921600 baud Winbond W83977CTF @ max. 921600 baud Winbond W83977EF @ max. 921600 baud Winbond W83977TF @ max. 921600 baud Winbond W83L517D @ max. 921600 baud Download HiSerial.sys Driver Setup (301 kB) Br ![]() |
Attention. On some pcs can boost speed up to 921Kbps on some the speed can still remain 115Kbps. See if speed boost on HiSerial shortcut on HiSerial.sys Settings.
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2003
Member: 31027 Status: Offline Thanks: 2
its not work for me what can i do now
#4 | |
