![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2003
Member: 20566 Status: Offline Thanks: 1
i have this problem very often how to solvet it and after this message the phones only beep and don't power on today was one c65 that i have try to unlock. Now the phone is dead and i can't flash it
first: what is the problem that i recive this messager (timeout) very often second: how to repair this phone now thanks |
#2 | |
Member: 38795 Status: Offline Thanks: 0
This message itself is not a problem as the unlocking procedure may complete for a longer time and the phone will be working and unlocked. In your case probably the battery was not fully charged .This is probably the reason why after that the simlock area was not written correctly and you see "timeout " message and the phone beeps after that.This is the same reason why flashing stoped at the 60% while you were flashing. To repair the phone charge up the battery or use external power . you can use test-point mode and reflash the phone with a file from the support area or use winswup flashing to enable normal mode again |
thanks for the replay i have repair the phone with testpoint
P.S i have one other c65 that i have recive dead it is version 41 and i can't flash it with version 12 testpoint is ok becouse the phone connect to software and say writing flash than nothing |
#4 | |
when i use the read phone option i si this info
IMEI: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ Phone ID:7<Û7ãDF and when i use the Repair OPtion i recive this info IMEI:354764xxxxxxxx Phone ID: 0089880D (Intel) |
