Go Back   GSM-Forum > Product Support Sections > No More Support/Temporarily Closed > SST-Dongle
Old 07-18-2005, 12:07   #1
gecata
gecata's Avatar
Member: 16994
SST 6.30 I/O error 998
I try to write full flash on cx70 with bad imei and got this error. After read on forum make a patch for imei repair and when try to vrite got sam error. What this mean and what can i do?
Thanks.
Old 07-19-2005, 18:14   #2
SST-GSM
SST-GSM's Avatar
Member: 38795
Thanks.
try to read info and post flash id info
probably a damaged flash IC
Old 07-19-2005, 20:17   #3
gecata
gecata's Avatar
Member: 16994
@ SST-GSM
You are right. Flash IC is bad. Thanks anyway.
Old 02-05-2006, 14:20   #4
benomano
Member: 73086
Hi.
I have same problem "I/O error..." with Siemens CXT70 writing flash.
Reading flash funktion is OK. Flash reading complete. And writing no !
SST software reading flash info: Flash Chip : F004E51F (Fujitsu), also
Fyz. flash chip in foone is AMD !
Please solution.
Thanks.
Old 02-05-2006, 22:37   #5
hitibiti
hitibiti's Avatar
Member: 24023
Sonork: 100.61317
Originally Posted by benomano
Hi.
Please solution.
Thanks.
you last one 7.02 betta if you still have problem , use 6.86 you can unlock it
Old 02-10-2006, 08:49   #6
Slavonac
Member: 27001
Hey people , i have that problems that on 2 phones when i read info about phones it write toshiba and error 998 , that phones are c65 and cx65 , it is not problem with flash IC im shure 100 % it is something alse .
It is not flashing with toshiba flash , maybe SST kill that phones it is only logical explenation .
We are waiting for solution !!!
Old 09-13-2006, 12:44   #7
bogg7
Member: 198113
did anyone solve the IO error 998 with SST, until now i have this problem with some phone, it read the flash I can backup but I cannot write flash, how can I solved this please help SST Team,
thank you
Old 09-13-2006, 13:01   #8
SST-GSM
SST-GSM's Avatar
Member: 38795
thank you
As described before this error indicates either damaged flash IC or bad flash file or file with read only attributes.
Sometimes flash chip problem is visible when you press "read info" button and it gives an invalid information.
Page generated in 0.06807 seconds with 6 queries
