![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2002
Member: 18200 Status: Offline Thanks: 18
A50 Blinking after Crack SST
Hi all,
I got this sety from another tech, who confessed that he tried unlocking the phone with Crack SST, then it was Wrong Software, Then he did REPAIR, then the phone now blinks only when powered. I flashed it with Original SST with flash from support area, Repair, Unlock, still same result. What could be wrong this time ? |
#2 | |
Member: 38795 Status: Offline Thanks: 0
For repairing this phone with original software please mail to support@sst-gsm.com |
![]() ![]() ![]() ![]() ![]() Join Date: Feb 2005
Member: 117496 Status: Offline Sonork: 100.83919
Use frreware FREIA, upload EEPROM, set Eeprom imei to ORIGINAL, UNlock and all will be fine.
Best Regards, karwos |
#4 | |
Who can send me the A50 eeprom bin ??? |
@SST-GSM, mail sent
Check mail |
use checkbox near the repar button and power on the phone when you are prompted.
make sure the the phone is really A50, not C45 for example that has a simillar PCB |
#7 | |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2002
Member: 18303 Status: Offline Thanks: 0
simple is make test point flash ...firmware EEPROM and unlock it again....or only unlock if EEPORM is ok.
#8 | |
Fullflashing or winswup flashing is needed if the phone becomes in a short perion in a "WS" again. The problem described by our customer here is different from the normal WS as the Software called as "SST cracked by BB-GSM" is a fake soft that makes the phone in "Wrong Software". Then normal unlock with the real SST is enough to fix it. |
![]() ![]() ![]() ![]() Join Date: Apr 2003
Member: 26955 Status: Offline Thanks: 4
wrong post.....edited
where is the repar eeprom ???
Every1 seems to know the solution, but no 1 has the Tools.
Can some1 pls paste the eeprom for A50 here ? |
please send us the info displayed when you press "read info" button
If the phone is A50. do the following 1. Upload fullrepair flash file from the support area . 2.Press repair button with repair x5x checkbox if SST displays "Bad EEPROM" in the previous step If the phone is C45 1.upload C45 flash file selecting A50 phone type 2.press unlock selecting C45 phone type |
Phone repiared, Thanks to SST Team,
Good soft, good team |
