| Motorola Hardware Repair Section here all threads Related to Motorola Hardware Servicing and Repairing. |
#16 |
![]() ![]() ![]() ![]() Join Date: Dec 2004
Member: 97043 Status: Offline Thanks: 0
motorola v3 power button not responding if i power on the phone the power but wount have any function again even if i want to off the phone until i remove the battery,but every other thing in and on the phone are working fine, i have even opened and cleaned the phone but still no responce from the power button it only comes on ...please help me...
| The Following 7 Users Say Thank You to segun For This Useful Post: |
#17 | |
![]() ![]() ![]() ![]() ![]() Join Date: Aug 2005
Member: 166746 Status: Offline Thanks: 0
came right. fixed
on the right hand top corner of the sim card connectors lies 3 diodes in a row horizontally, i changed two of them, phone is 100% now. |
| The Following 2 Users Say Thank You to silveraxe For This Useful Post: |
#18 |
i need help....
Im busy ******* a motorla c205 and a T190 LCD, they seem to be the same, I cannot get the LCD cable to stick onto the pcb, everytime i apply heat it comes out somehow... can anyone please assist with this, as this is very frustrating for me when i cant get something right (which i got right before) thanks
| The Following User Says Thank You to silveraxe For This Useful Post: |
#19 | |
![]() ![]() ![]() ![]() ![]() Join Date: Feb 2005
Member: 115826 Status: Offline Thanks: 6
Ok pal .Firts not use ordinarie souder iron point in this work use a 15 W souder Is Preferible Antex and Flux paste ![]() Use a plate tool to hold the screen ribbom put souder past or flux in all the video line then put the ribbom screm hold the ribbon and whit presion whit the Desruptor ![]() And very carefull let a little down space in the ribbon flex to u can put the sourder to hot the flux or souder past ( the sourder past mix whit the soulder line )ok is all |
| The Following 4 Users Say Thank You to Amartt For This Useful Post: |
#20 |
wow... what a detailed description.. thanks man.. its working now,
all is ok 100% ![]() 2) I have 4 t190's not charging, 3 of them i changed the block they are fine now the last one is giving me trouble, i changed the block so now its recognising the charger and is charging for 4 seconds, then as soon as the light goes on it restarts charging process and does this for ever... I changed every diode and charging controller at the bottom of the phone near charging block and changed the light controller on the front bottom of pcb (due to desperation lol) what can solve this, its still doing the same thing! |
#21 |
solution found
I found a solution on the forum:
will try it and post tomorrow... reset eprom & use this diagram... |
| The Following 18 Users Say Thank You to silveraxe For This Useful Post: |
#22 |
![]() ![]() ![]() ![]() ![]() Join Date: Oct 2003
Member: 40602 Status: Online Thanks: 53
I have a problem with C650 blank LCD. Phone work normally except for blank LCD. Already flashed with SmartMoto, change a new LCD. Got no clue at all. Any help?
BR, s1emens |
| The Following User Says Thank You to s1emens For This Useful Post: |
#23 |
![]() ![]() ![]() ![]() Join Date: Jul 2003
Member: 34710 Status: Offline Thanks: 7
sevgigsm,can you please send me pictures for motorola c333 speaker ways?the speaker sometimes work,and at times not.i have tried changing it but still the same problem
| The Following User Says Thank You to HAJGSM For This Useful Post: |
#24 |
RE:
I have a c650, came in for LCD, I fitted new LCD, phone is fine, loudspeaker is working fine, but the handsets speakers is not working at all and the speaker I tested its 100%. any solution pls??? |
#25 |
i have searched new motorola hardware solutions,but didnt see my solution,c333 speaker ways.can anybody help me?
#26 |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2005
Member: 111665 Status: Offline Thanks: 14
c-350 motorola only on/off button working no other button is working ! its not a water damage phone ! board is clean ! I removed the keypad sticker and check with tweezers ! still no button working ! I need solution plz !
#27 |
![]() ![]() ![]() Join Date: Mar 2005
Member: 123133 Status: Offline Sonork: 100.999
hi
i have a c975 .. in charging fault.. when we attach the charger into the mobile he shows charging but not save.. also mobile heat up when we try to charge it any one have complete solution Br Kuku |
#28 |
Member: 170619 Status: Offline Thanks: 156
any one has motorola 3788 schematic plz upload it
#29 |
![]() ![]() ![]() ![]() Join Date: Oct 2001
Member: 6569 Status: Offline Thanks: 2
can anybody help me with c975 keypad not working, I think it has a matrix and that is not available in the market.
gsmsharing. |
| The Following User Says Thank You to gsmsharing For This Useful Post: |
#30 |
Member: 168352 Status: Offline Thanks: 2
can anybody help me 4 C-115 spk not working . changed d spk 3 times
