![]() ![]() ![]() ![]() ![]() Join Date: Feb 2002
Member: 9411 Status: Offline Thanks: 0
problem with install
i use crack software, now i buy original and after install i have pc clock tampetrd.
clock and date is up to day. |
![]() ![]() ![]() Join Date: Aug 2003
Member: 36951 Status: Offline Sonork: 100.63212
try to change date and time in BIOS .
this might help. br |
in bios date and time is up to date, anything else?
![]() ![]() ![]() ![]() Join Date: Jul 2004
Member: 71246 Status: Offline Thanks: 0
HI
FIX the time and date in windows and U will have working SST OR U have instaled old version!!! BR |
i have vers 6.30 and clock is up to day but same error
So U have some patch in registry I think(couse using SST cracked),try to delete them and will work I hope!!
BR |
i allredy deleted from registry
Member: 38795 Status: Offline Thanks: 0
before installing SST-Dongle software please fix your system date!
do you mean reinstall windows?because time and date is ok
Member: 39069 Status: Offline Thanks: 41
Why I nstall evey simple: Download update v5.32 or v5.38 than intall it. after intall will see shortcut on destop. if y ou run this program will ask for key. Just delet it.
***download version v6.30 than intall, will see shortcut again on destop.( not yet open program. plug dongle to usb port. will ask for driver.( if you have use cruiser, UST Prodongle just remove it out first). brow to : C:\Program Files\SST-GSM for smart card driver. after comlpete you can use program no problem but i dont know what cable you use, SST USB cable or use with USFx box ? |
problem solved,new windows!
