08-11-2005, 10:59 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 45
Member: 55631 Status: Offline Thanks Meter: 55 | -= Use Cracked HWK With Your Normal UFS =- Follow The Following Instructions... - Change your box serial number to 40639 using UFS_Maintenance_v20. - Run DCTX_1.3k & connect, enter activation string 0528E75CB841269710 and click ok on all error messages. - click on update firmware. (If your box is already updated with latest ufs firmware then you can skip next procedure and simply run hwk cracked stuff and enter activation strings give below and start using hwk enabled applications.) - Browse and locate Req.fbi and upload to box. - Your 40639.req will be generated in the same folder where dctx_1.3k is located. - Download the attached Req2Fbi.part1.rar & Req2Fbi.part2.rar and unpack them to root directory of your C: drive, it has the following files in it. 1. Req2Fbi.exe 2. Req2Fbi.bat 3. Req.fbi 4. Dctx_Ufs_12m Usage of Req2Fbi is as follows. Syntax: Req2Fbi <Req Filename> Example: on C:\> type Req2Fbi 40639.req And 00040639.fbi will be generated Under root directory of your C: drive, a Req2Fbi.bat is also included for dummies so after placing 40639.req in the same folder they can simply edit this .bat in notepad and they can replace the text "40639.req" with their own ?????.req filename and double click (Execute) this .bat file and 000?????.fbi will be generated in the same folder. - Now place Dctx_Ufs_12m in your default phoenix folder and execute it and connect. - Cancel string asking text box and click ok on next error messages. - click on Update Firmware & locate the 00040639.fbi file you generated earlier. (Result: BOX_KEY updated) - Now close it and run dctx_1.3k and connect. (Update Firmware If Asked) - Now download HWK cracked 3 programs and run them. (Already Given) - Their activations strings are given here under. - It's done and you are ready to go. Other Activations Strings are as follows. Serial: 40639 Nokia: 0528E75CB841269710 Motorola: 06DBC4D90627002911 Samsung: 0C87F1351F2983FF58 Ericsson: 011D9545B9067607CD Siemens: 0DE412410061899904 HWK-Nok: 1E0871AE30D32EBE21 (Cracked) HWK-SE: 1DD40341FEC43C93FF (Cracked) HWK-Sam: 1CD0BE870F64127734 (Cracked) Serial: 41824 Nokia: 05175F0416C3292E04 Motorola: 06C6D7DF071DF6DB1B Samsung: 0CF5C5F8F41D042ED0 Ericsson: 0186F9D65A12D38F19 Siemens: 0DCD75C4BF82E79194 HWK-Nok: 1E2AC517047F7B3906 (Cracked) HWK-SE: 1D36E2A1C699B81EE5 (Cracked) HWK-Sam: 1C3688CF0686017230 (Cracked) More can be found in the forum… :-D Warning: Switch back to your original serial number before going to use next official update from SarasSoft, If you don't know what you are doing then don't do this... [PaWaa] Attachments: UFS_Maintenance_v20 Req2Fbi.part1.rar Req2Fbi.Part2.rar Last edited by pawaa; 08-11-2005 at 15:38. |
The Following User Says Thank You to pawaa For This Useful Post: |
08-11-2005, 11:26 | #3 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | all i need to tell you plz don't cracked if you need buy original.....for using this you have to change your serial number to cracked serial......and you don't need req2fbi convertor......... |
08-11-2005, 11:28 | #4 (permalink) | |
Member: 55631 Status: Offline Thanks Meter: 55 | Quote:
but if somthing is done wrong you can start again from the beginning. and if you want to undo all this procedure, switch back to your original serial number... (shhhhh.......) [PaWaa] | |
08-11-2005, 11:41 | #6 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Tested with this method last nite.. But once we can, we do not need ask other to calculate our fbi.. we can play with it when we like. I can confirm that ths method is working. regards |
08-11-2005, 11:41 | #7 (permalink) |
Insane Poster Join Date: May 2004 Location: Essex Age: 55
Member: 65585 Status: Offline Thanks Meter: 0 | All what u speak is wrong , no need all the to get it working , only change serial , replace cracked with original , update strings in Diga after u calculate strings with normal calculater .... Empty all box as new .... No need fbi to do this |
08-11-2005, 11:45 | #8 (permalink) |
Banned Join Date: Jul 2003
Member: 34760 Status: Offline Thanks Meter: 2 | @koteya: yes, you are absolutely right. To change serial you do not need to reactivate the box. Simple use the UFS maintenance tool that was posted earlier to change the serials in the FTDI's external EEPROM and in the ATMega's EEPROM. |
08-11-2005, 11:55 | #9 (permalink) |
Member: 73565 Status: Offline Thanks Meter: 5,062 | koteya - avenger: 100% agree.. in this case, i just got a little accident, i tought there was new firmware (above 2.6) So, i play arround with .fbi.. then after i received the calculated file, i see that ther is no new firmware above. The quick and save is using the method that u mentioned. regards |
08-11-2005, 12:10 | #11 (permalink) |
Banned Join Date: Oct 1999 Age: 55
Member: 563 Status: Offline Thanks Meter: 22,328 | You know what is strange guys, so many ppl used Diags until now, and no one found any virus in it, it is exact the oposite as described by cheater, lier and SarasSoft manager Odia The Ultimate **** in this thread : http://forum.gsmhosting.com/vbb/showthread.php?t=225280 As you see, after his post, he closed the thread, so ppl can not reply there to confirm that the software is authentic and fully working. Another "truth" by HWK team and i guess same "truth" as the 4000 damaged HWKs. B.R., Raskal |
08-11-2005, 12:13 | #12 (permalink) |
No Life Poster Join Date: Apr 2001 Location: รำมว&#
Member: 3956 Status: Offline Sonork: galletto3 rules :D Thanks Meter: 55 | Risky?, risk zero %, btw, working 100% tested, http://forum.gsmhosting.com/vbb/show...4&postcount=16 best regards Invisible |
08-11-2005, 12:13 | #13 (permalink) |
No Life Poster Join Date: Jun 2005
Member: 155820 Status: Offline Thanks Meter: 60 | you can also use this String and Sr NOs........... Serial:62139 Strings: Nok_hwk : 1E3EF46A188C94CF04 SE_hwk : 1D5BEA9A6437ECCB26 Sam_hwk : 1CA34A2B9981B68DC7 41824 Nok : 1E2AC517047F7B3906 SE : 1D36E2A1C699B81EE5 Sam : 1C3688CF0686017230 20886 Nok : 1E0687DA20AFF9941E SE : 1D8B31152A9508B468 Sam : 1C23C461BA6101D478 60217 Nok : 1E784560342674435F SE : 1D9A1F4808B258FA0C Sam : 1C5E406E6D505C3268 4559 Nok : 1EDD5C5F3396A2CF25 SE : 1D59EC021239EC8579 Sam : 1C75166A55185E6939 40639 Nok : 1E0871AE30D32EBE21 SE : 1DD40341FEC43C93FF Sam : 1CD0BE870F64127734 |
08-11-2005, 12:17 | #14 (permalink) |
Member: 65585 Status: Offline Thanks Meter: 0 | Yes true , 1000000 % as simple as That , no need all this story , want help contact me .... i will be glad to help u get HWK working and provide u with easy cable drawings ;-) AND IF rascal will give space will upload all flash files ......... BR |
Asking again as been removed!How to use upgraded hwk with (2.07)PLEASE HELP!!! | lasty | HWK | 2 | 01-10-2009 20:54 |
