![]() ![]() ![]() ![]() ![]() Join Date: Feb 2002
Member: 9411 Status: Offline Thanks: 0
a 70 problem!!!!!!!!!!!!!!!!!!!!
i unlock the phone with v6.61 and only siemens be inspired on lcd.
i write a70- repair files and same problem, i need help. thanks |
no one have this problem????
![]() ![]() ![]() ![]() Join Date: Aug 2005
Member: 168965 Status: Offline Thanks: 0
try to update with swup
#4 | |
Member: 38795 Status: Offline Thanks: 0
Have you checked the phone before unlocking? If not fully charged battery or bad cable you may receive " Wrong Software " Message. In this case press unlock again. The problem you have described is strange and such problem should not be caused even if the battery is at low voltage or the cable gives errors in service mode comunication |
#5 | |
for me update from switched on phone working with cutted testpoint
can you send me your winswup?
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2003
Member: 19987 Status: Offline Thanks: 1
Just change baudrate or cable must work with winswup....
Regards Mackie |
#9 | |
![]() ![]() ![]() ![]() Join Date: Jan 2004
Member: 51104 Status: Online Thanks: 0
a70_v1401 a70_140202 a70_140305 a70_v140406 a70_v140507 a70_v140608 a70_v140712 a70_v149109 a70_v140203 a70_v140304 a70_v149013 a70_v149200 a70_v149210 a70_v149611 a70_v149814 best regards
i have this error, i use cable without ignition
Try without skip...and try other baud and other cable....
Regards Mackie |
i*m made it to flash but at 61% prog stop and now phone is not powered on.
#13 | |
1. Not fully charged battery 2. Bad cable. 3. Bad flash block Now repairing for this phone will be more difficult.Please wait until the next update. |
do you know when will be next update sst team?
#15 | |
what should i do? |
