![]() ![]() ![]() Join Date: Jun 2005
Member: 153263 Status: Offline Thanks: 0
SST gives me messege: Please update SST
when i start the program the window opend and there is a small window message says:Please update SST and that's it,it works few days before, but now only this message. my version was 6.50, i download 6.61 and install it but THE SAME
what to do to work with sst thanks in advance |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2005
Member: 103544 Status: Offline Sonork: 100.75677
you have purchased this sst?
![]() ![]() ![]() ![]() ![]() Join Date: Apr 2004
Member: 61851 Status: Offline Thanks: 21
Maybe a small bug I am sure SST-GSM will check it out and fix it.For now if you dont need it do not use this new version,reinstal old version and write to support section at SST-GSM.
regards |
#4 | |
Member: 38795 Status: Offline Thanks: 0
It is needed that your system date is set correctly before installing SST |
I set my system date correctly but now the message says : PC clock tampered
what to do?? |
#6 | |
now v6.50 works on win'98, i remove all SST programs,drivers, even in registers with regcleaner,and after 3 hours deleting,instaling..... it now works on '98, but on XP it seems to be impossible, please SST-GSM tell me how to completely remove instalation of SST where it puts f... files,i think if i remove SST completely and after that install it with the correct system date it will work.waiting your replay,hope to help me
regards |
loool ... i think he have a cracked version
IT IS NOT CRACKED VERSION!!!!!
normal sst dongle, but something is wrong here |
#10 | |
I set it correct but now what, i must wait may be months for next update?Why it is made that way, what importance have the date? now it works somehow on '98, but how long....
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2003
Member: 19987 Status: Offline Thanks: 1
Your dongle is ok...problem is that you used cracked version before you purchase your dongle and now cracked version confusing new one....thats why everything work OK on win98...you must format your hard drive and install new clean dongle version...and then everything will be OK...
Regards Mackie |
#13 | |
Member: 42264 Status: Offline Thanks: 7
![]() ![]() ![]() ![]() ![]() Join Date: Jun 2003
Member: 31049 Status: Offline Thanks: 0
I get same error, this ver. was working until now?!
btw I try on xp & 98se on same comp., i didnt change time.... Last edited by danilo_nop; 08-28-2005 at 01:27. |
Member: 65015 Status: Offline Thanks: 0
got the same problem today. been using it for 3 months already.
