Go Back   GSM-Forum > Product Support Sections > No More Support/Temporarily Closed > SST-Dongle
Old 08-25-2005, 10:39   #1
Mistreated
Member: 12509
To SST, I need rus lang for A70 14 ver
PLS, put to support section !!!
br!
Old 08-25-2005, 11:25   #2
garfild
garfild's Avatar
Member: 51104
br!
download swup for a70 here
a70_v1401
a70_140202
a70_140305
a70_v140406
a70_v140507
a70_v140608
a70_v140712
a70_v149109
a70_v140203
a70_v140304
a70_v149013
a70_v149200
a70_v149210
a70_v149611
a70_v149814
best regards
Old 08-25-2005, 13:15   #3
Mistreated
Member: 12509
Afte cut TP, SWAP not see phone
Afte cut TP, SWAP not see phone.
br!
Old 08-25-2005, 15:49   #4
cybercom
cybercom's Avatar
Member: 5745
br!
if you think for SWUP you are very wrong,just power on the phone and do not check any box-es at swup window,when you pust start button phone will go off automaticly and start with flash !
Old 08-25-2005, 18:50   #5
Mistreated
Member: 12509
Not flash
==just power on the phone and do not check any box-es at swup window=
It's Ok.
==when you pust start button phone will go off automaticly=
It's Ok.
==and start with flash !
No. = Error on waiting for Ack EOT=
Old 08-26-2005, 10:42   #6
hallo
hallo's Avatar
Member: 21365
Yes, problem with WINSWUP.....
..after cut test point and unlock, phone is normaly conect on WinSwup and stops on 73%, and now WinSwup says "Can't conect mobile with bootstrp loader" . SST can't read flash from working one and I have dead phone now.
I gona try to remake test point and than try to do WinSwup. I let You now what is going on.
Cheers
Old 08-27-2005, 18:18   #7
[c]Cinek
Member: 40756
Phone must be in "Service mode" (use "x55 contrast tool" to do this)
Do not check any box-es
Press start and phone boot and flash ok
Tested with thousand Siemens and A70 too
Service mode is a way which allow to use SWUP with all Siemen's phone after cutting TP.
But sometimes you must play with speed and try all speed options.
Old 08-28-2005, 20:30   #8
hallo
hallo's Avatar
Member: 21365
@[c]Cinek...
.. U menage to put dead siemens A70 in Service Mode using Conntrast Tooll(or any other tool)???????????????!!!!!!!!!!!!!! Sorry, but I just CAN'T bolive in that! For every case I just try to do that and......how You menage to do that? WinSwup kills bootcore(I think), and phone can't boot any more on any tool(exept flashing with Martech), so how You(again) menage to put that thasuneds off A70 in serviceMode?
Old 08-31-2005, 00:00   #9
[c]Cinek
Member: 40756
Sorry "hallo" i wrote this info to "Mistreated" and it work only if phone be alive or only beep.
Old 08-31-2005, 10:22   #10
hallo
hallo's Avatar
Member: 21365
Ok..
..Sorry for my reaction. Cheers
Page generated in 0.10077 seconds with 6 queries
