| NON Siemens Brand (ODM Phones) Do you know that C62 is not a Siemens Manufactured !? here in this section we Throw all non Siemens-Benq related Threads like C62, CFX65, SF65, CL75, CL50, S40, U15, C30,Xelibri. |
![]() ![]() ![]() ![]() Join Date: Dec 2004
Member: 96525 Status: Offline Thanks: 1
C62 flashing
I tried to flash a Siemens C62 phone.
I used the following instructions: Siemens C62 Flash tool Installation: 1. Install “flash_programmer_for_siemens_setup.exe” 2. Copy “Hd0503-058-m” and “Hd0503-067-m” into “C:\Program Files\microcell\Flash Programmer” folder. 3. Install “PL-2303 Driver Installer.exe” Settings: 1. Select Options -> Settings ->C62 2. Set Baud rate to 460800 bit/s 3. Select Root folder for software releases 4. Choose Software release 5. Choose Language package 6. Choose Customization package Phone flashing process 1. Switch OFF the phone 2. Plug-in flashing cable 3. Press Flash button 4. Press shortly power button Program detects correctly the phone, reads details, but i cannot start flashing process. I tried both serial and USB cables. Is there a special cable? I repeat: program reads the phone. |
![]() ![]() ![]() Join Date: Aug 2005
Member: 169854 Status: Online Thanks: 0
Yes there is a speacial cable for C62
you can find it in attachment file pay attention +12V is external power to Pin 9, don't put more than +12v and don't forget the diode 1N4148 this cable works perfectly , i already tried it , if you have any question i'm here to help you good luck friend |
I don't have a powered cable.
I modified a C55 cable, i shorted pin 3-5 and pin 4-7, i applied power (12V, 50 mA) through a 1N4148 diode, but flashing still doesn't start. Does it have to be a powered cable? |
![]() ![]() ![]() Join Date: Jan 2004
Member: 48552 Status: Offline Thanks: 12
Hello,
I have the cable from the schematic, but with flash programmer i get: Waiting phone restart... Uploading flash algorithm... Flashing failed. The phone is not responding to load header command. I tried several phones, but no joy ![]() Any ideas? |
Member: 65419 Status: Offline Thanks: 44
hi.i have tried to install flash programmer version 2.71 and 2.83 but everytime i open the program it says:
there are no software releases available in D:\program files\microcell\flash programmer i have tried different instruction that i have red in the forum but it always the same. what i am missing here? any suggestion please. brgds meneleo |
I already faced the same problem meneleo and soleved it
try to check if the folder contains the flash is like this : HD0503-083-M and no subdirectories except : Flash , cust , language and the flash's file name is like this : HD0503-083-001-M.SSW if not rename the directory and flash file if your problem persist , i'll give you an other solution Good luck and in the same time I faced the same problem of non flashing , it displays phone non responding to load header command, but i'm trying to find the solution, when it'll be done i'll give it to you, good luck for all |
![]() ![]() ![]() ![]() Join Date: Aug 2004
Member: 76714 Status: Offline Thanks: 2
pls give me the programs
#8 | |
hi. ihave tried as per your instruction but still the same
anymore advice please thanks brgds meneleo Quote:
don't waste time , here is a good link to download different versions of C62 and it's 100% tested
http://c62.siemensgsm.ru/soft/index.html but don't rename anything it's perfect just check the contains of directory per exemple: V28 it contains (hd0503-097-m\hd0503-097-m\HD0503-097-M) so pay attention to cut only the last directory HD0503-097-M contains (Flash, Cust, Lang) and paste it directly in directory C:\Program Files\microcell\Flash Programmer look at the pic and you'll understand more good luck friend |
#10 | |
hi.thanks for the link.i have already downloaded and the software is working now.i use the cable with 12 volts supply in pin 9.but this is what i get when i press flash and power button.
Flashing failed. Detecting HW version failed. could there be some problem in the hardware? brgds meneleo Quote:
Member: 223666 Status: Offline Thanks: 0
With the flash programmer, can I connect directly the PC COM1 port to the phone with the cable or do I need a "Unibox" in between ?
![]() ![]() Join Date: Jan 2005
Member: 105468 Status: Offline Thanks: 0
if you have the right cable you can flash it without the box
good luck! |
![]() ![]() ![]() ![]() Join Date: Oct 2002
Member: 16625 Status: Offline Sonork: 1578753
hello all
my cable is able to read log with logger and codes with griffin, but when i want to flash the phone i get this message, please help thx when i changed config file to 1 or 3 it is error code 6 if config file is 4 or 2 i get Initializing... Uploading flash algorithm... Waiting phone restart... Uploading flash algorithm... Reading information from phone... Loading software file... Software file 'HD0503-097-001-M.ssw' loaded. Loading language file... Language file 'HD0503-LNG-097-M-92.SSW' loaded. Loading customization file... Customization file 'HD0503-FFS-097-M-109.SSW' loaded. Flashing software (HD0503-097-001-M.ssw)... Flashing software failed. The phone is not responding. |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2005
Member: 135671 Status: Offline Thanks: 183
Yes the same me problem .
ploading flash algorithm... Waiting phone restart... Uploading flash algorithm... Reading information from phone... Flashing failed. Updating phone software to older version is not allowed. What is problem in Flash phone. |
Member: 280784 Status: Offline Thanks: 0
Hi everyone,
this is my first post in this forum. I have a C62 Siemens and I'd like to build a serial cable for it, but I haven't a good schematic. There's someone that can send me it? thanks a lot |
