Nokia Hardware & Hardware Repair all what you need for Hardware Repairing for Nokia Phones. Before writing any thread here try to check the Frequently Asked Questions Section. |
11-01-2005, 11:35 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 45
Member: 55631 Status: Offline Thanks Meter: 55 | -= Band Convert Nokia 6101B/6102 to 6101 =- No software modification is required because 6101b is already tri-band (850&900/1800/1900) but if you want then you can simply flash it with RM-76 Data Package. Hardware Modification A self explainer picture is attached but if you are unable to understand then consider following lines a short description. 2 network filters (Rx & Tx) are needed to be replaced with proper filters which can be taken from any damaged 6230 or similar phone or you can redirect them using a capacitor, for batter performance you can try different values. [PaWaa] |
The Following 3 Users Say Thank You to pawaa For This Useful Post: |
11-04-2005, 18:29 | #5 (permalink) | |
Member: 55631 Status: Offline Thanks Meter: 55 | Quote:
[PaWaa] NO INSULTS Last edited by Syed; 11-10-2005 at 18:15. | |
11-06-2005, 14:08 | #7 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: india
Member: 135945 Status: Offline Thanks Meter: 85 | Quote:
Thanks for the info! its very useful, but needed to know if we can use any value capacitor? WBR ReyTech. | |
The Following User Says Thank You to ReyTech For This Useful Post: |
11-06-2005, 14:20 | #8 (permalink) |
Freak Poster Join Date: Oct 2003 Location: Philippnes,Pasig City
Member: 42165 Status: Offline Thanks Meter: 35 | and what should be the capacitor type to be used and its value??? I really appreciate this info you shared to us... THANK YOU VERY MUCH |
The Following User Says Thank You to Abelardz23 For This Useful Post: |
11-10-2005, 05:51 | #9 (permalink) | |
No Life Poster Join Date: Jan 2003 Location: Hong Kong. Age: 47
Member: 19979 Status: Offline Thanks Meter: 116 | Quote:
WBR Syed | |
11-10-2005, 08:53 | #10 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Lithuania Age: 40
Member: 19265 Status: Offline Thanks Meter: 92 | @Pawaa Dont be angry, and I dont want to say, that info you posted is not valued. It's ok, just my question, what from that info for nokia, why they started putting that kind of info. p.s. I was smart enaught to find that info ~1 month till you posted, and understood withot sm 'modifications' ... no need to be insulting. B.R. Alkapone |
11-10-2005, 20:38 | #11 (permalink) | |
[PaWaa] | |
11-15-2005, 10:37 | #13 (permalink) | |
Then u mean to say that no need the hardware modification as well? and if hardware modification is necessary then can we use the jump thru capacitors as we do in 1100? and can u pls inform how is it to be jumped? like in 1100 "last contact to the center contact" & in 6101 how is it? or is it same? WBR ReyTEch. | |
11-15-2005, 11:55 | #14 (permalink) | |
What every i posted is based on experiances. [PaWaa] | |
11-15-2005, 14:59 | #15 (permalink) |
Member: 19979 Status: Offline Thanks Meter: 116 | yes u can use capacitors.. but will have problems in network sometimes... so better to use proper filters u can skip flashing but still need to write PM !! WBR Syed |
convert 6102 to 6101 900MHz | reaz.com | Nokia Hardware & Hardware Repair | 28 | 04-20-2012 09:18 |
how to convert nokia 2115 1900mzh to 800mzh | victor2006 | Nokia CDMA | 2 | 05-31-2009 07:30 |
Need to convert nokia 1200 rh99 to nokia 1200 rh 100 | krich70 | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 05-23-2009 00:47 |
no network nokia 6101b wanna to change 6101 | tarey888 | Nokia Hardware & Hardware Repair | 0 | 10-30-2006 11:07 |
nokia 6101b refuse to sent message help me | maxheadquarters | Nokia Hardware & Hardware Repair | 0 | 03-29-2006 23:59 |
