Member: 102577 Status: Offline Thanks: 2
Widcomm 5.0.1.802
Hello guys and gals, i have a little gift for you all
![]() A little new version of widcomm. I know, i know, it's the smalled point release of a widcomm version yet, but hey, it's higher then the last one :P Got it from the Logitech Setpoint 2.46c release CD. Get the 32 bit version here : http://www.megaupload.com/?d=BJ0NDHW6 and the 64 bit version here : http://www.megaupload.com/?d=PJM4IL7Y Phantasm, hope you can patch this one for us ![]() I'll upload the 32bit one as well. Adi Last edited by adisor19; 11-23-2005 at 02:34. |
Member: 173825 Status: Offline Thanks: 0
no problem, 32 bit version "servicepack" directory is ready now....
http://www.megaupload.com/ru/?d=HKH6KNHJ Testing please ))
Member: 102513 Status: Offline Thanks: 3
All Good!
Widcomm 5.0.1.802 32 bit with above service pack works great! Another awesome patch by all you guys!
Member: 40901 Status: Offline Thanks: 0
Try this for the x64 version - http://www.megaupload.com/?d=EBNPPEK0
Let me know how you get on. Also if you get the "Bluetooth license check failed. Please make sure that the bluetooth device you are using is licensed..." please post the exact message, there may be a number between the words CHECK and FAILED. I have placed these numbers into the various dll's so that I can see which dll is triggering this. |
![]() ![]() Join Date: Oct 2005
Member: 190415 Status: Offline Thanks: 0
Hi, Phantasm. I got it working for like 5 minutes, maybe some minuts more when the tray icon turned red again and the message popped up "license failed bla bla.... No numbers between the words. Damnnnnn, I never had it working this long. I really thought it would stay working.
Can you overwrite this DLL (btChooser.dll) into system32
http://www.megaupload.com/?d=TK9NYZ0J and see if it comes up with a number in the message then. Thanks. Phantasm |
#7 | |
#8 | |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2003
Member: 21937 Status: Offline Thanks: 72
thx |
Phantasm this is odd. I tried to do the same what you are doing. opening the dll's up in hex view and adding a number between words in that well known message, so you can know which dll gives the message. I've gone through all of them in the Data1.cab install package and I found only 3 files containing that message.
btchooser.dll BtWizard.dll BTNeighborhood.dll after overwriting the installed ones with these, still the message appears without any number in between the words. |
its in bttray.exe as well (in 2 places), but yes I too am now getting that error and cannot figure out where its coming from.
Also when it appears, if i end-task BTTray.exe it disappears, so its definately either coming from bttray.exe or a DLL that is loaded from bttray.exe oh and its also present in the 32bit version of the files, but ive never seen that error message pop up on any of the 32 bit releases. |
Well, if you need help with testing I'm here.
#12 | |
Hmmm... I use latest version of RAR, try to upgrade winrar to last version.. if problem not solved, i repack with zip |
Member: 126419 Status: Offline Thanks: 0
Hi, does this drivers work now or not? I mean the problems because of the license...
Maybe this files will help here too? http://forum.gsmhosting.com/vbb/show...3&postcount=23 |
#14 | |
Don't use the patch for the OLD version. Use the one mentioned above. Adi |
Member: 202921 Status: Offline Thanks: 0
works perfectly for me - thank you very much!
Check out the BT Server Spy Lite application - very handy if you need to do any BT programming... |
