11-23-2005, 10:52 | #1 (permalink) |
Freak Poster Join Date: Apr 2004 Age: 49
Member: 61077 Status: Offline Thanks Meter: 3 | Problem while flashing W550.... For ARM is ok but while flashing FS it's stop at 42%. I try to change from eu1,eu2,eu3,eu4 but the same stop at 42%. What's the problem ? Is it 7.10 BUGS ? |
11-23-2005, 14:53 | #2 (permalink) |
No Life Poster Join Date: Aug 2008 Age: 53
Member: 1841 Status: Offline Thanks Meter: 469 | W550 has 2 flash chips - NOR and NAND. Cruiser can't write data to the NAND flash if the phone was booted via TP. Therefore you should convert the phone to brown CID49 first and then reattach normally, without using testpoint. Only then you may correctly flash W550 FS. Remember to convert the phone back to red CID49 (via TP) or to repair EROM (without TP), but the phone will remain brown CID49. Note to all: We are going to update user manual as soon as possible. |
11-23-2005, 15:24 | #5 (permalink) | |
No Life Poster Join Date: Dec 2002 Age: 47
Member: 18855 Status: Offline Thanks Meter: 1,939 | Quote:
i try what u say to convert to brown but the result is Replace failed | |
12-03-2005, 19:56 | #7 (permalink) |
No Life Poster Join Date: Feb 2005 Location: (United States Of GINGOOG CITY Age: 48
Member: 120328 Status: Offline Thanks Meter: 243 | not replace brown... no select ur w550!just attach ur phone...i try to flash my phone phone its work 100% ok my phone...no replace it ur convert to brown our red... |
12-03-2005, 21:20 | #8 (permalink) |
No Life Poster Join Date: Jan 2004 Age: 45
Member: 49581 Status: Offline Thanks Meter: 73 | if you don't convert to brown, you cannot flash FileSystem part ~ um ... i have to use 2 tools to flash it ... I couldn't replace the color, so i have to use another tool to convert the color ... but that tool cannot flash it correctly ... then i have to use cruiser to flash ... bug bug bug in every tool on CID49 .. Last edited by gwaai; 12-04-2005 at 04:54. |
12-08-2005, 08:47 | #10 (permalink) |
Freak Poster Join Date: Apr 2002 Location: Europe Age: 46
Member: 10946 Status: Offline Thanks Meter: 15 | Thats because you did not attach your phone with test point adapter. If you attach the phone with test point all the flashing options are activated else only the ARM option is activated. |
12-08-2005, 08:50 | #11 (permalink) |
No Life Poster Join Date: Oct 2002 Age: 39
Member: 16107 Status: Offline Sonork: 100.58402 Thanks Meter: 26,411 | ok its done ARM Flash all done but it gives error in flashing FS at 42% tried with different FS flash ... it always give error in the middle wbr Siroya |
12-08-2005, 14:49 | #12 (permalink) |
Member: 1841 Status: Offline Thanks Meter: 469 | Do not flash FS via TP! Flash it when attached normally. Flash it as Main FW (you will have to change file extension). Unfortunately I can't upload new version of Cruiser now. |
problem with flashing W550 help | alexvideogames | Universalbox | 1 | 08-10-2007 21:15 |
error while flashing w550 | gsmservices | Cruiser Suite | 1 | 04-15-2006 08:17 |
Problems while flashing NPL-1 | lexwon | Phoenix Black Box | 0 | 02-02-2005 11:28 |
Problem while flashing with DIV under XP | airboy | DIV | 0 | 10-31-2004 17:14 |
V50 f0.14.04 strange problem while flashing | KaToT | Motorola Old Legacy (EMMI) | 4 | 11-08-2003 14:46 |
