![]() ![]() ![]() ![]() Join Date: Jan 2003
Member: 19831 Status: Offline Thanks: 10
BF3 cannot connect
I have an alcatel bf cable with external power supply that refused to connect to any software.I have used this cable before wray and heinrich but now it canīt connect at all to any software even Vygis cracked.I was forced into buying 9 in 1 alcatel cables but to no avail,Can someone olease help me out.
Thanks in advance |
Member: 82155 Status: Offline Thanks: 2
me too i have the same problem even with original vygis
#3 | |
![]() ![]() ![]() ![]() Join Date: Sep 2003
Member: 39097 Status: Offline Thanks: 0
Well, there's either a cable problem or operating system problem. Which version of software and what OS are you running? |
I am running on Xp Professional with sp2.I have tried increasing and decreasing my pwr supply still didnīt help but I have used this cable in the past on XP with no problem
#5 | |
As for the power supply, 5v or 9v should be good. |
![]() ![]() ![]() ![]() ![]() Join Date: Apr 2000
Member: 1233 Status: Offline Thanks: 2
Or Try to use WIN98.
![]() ![]() ![]() ![]() ![]() Join Date: Nov 2005
Member: 197720 Status: Offline Thanks: 12
the problem could still be from your cable try universal box and caBLE THAT COULD HELP
![]() ![]() ![]() ![]() ![]() Join Date: Aug 2005
Member: 166746 Status: Offline Thanks: 0
Hi
My alcatel 5 in 1 com cable with 9V power adapter plugged in, works perferct in henrich. but the phones version is not supported, so i need to connect it to vygis cracked, but vygis cracked keeps on saying, error error error, @ 12% cannot load boot. but the LG 1200 works 100% on vygis. any clues??? |
#9 | |
Which Alcatel phone you're trying to connect? If you have some other model, try it with Vygis too... |
Ok excellent peoples !!!!
ITS UNLOCKED !!! I managed to downlaod this version of henrich 523v3.exe it works like a charm, first it says usb dongle not found, when i chose windows me/98 comp and disabled visual settings, it unlocked the phone in 3 seconds :> with my 5 in 1 com port alcatel cable, 9V powered... ![]() great program 523v3.exe Henrich. WBR |
#11 | |
Download at :
w w w . u n l o c k e a s y . c o m |
yeah,
just as amoneysaid: thats where i got it from. take care you wonderfull people on GSMFORUM :> |
![]() ![]() ![]() ![]() ![]() Join Date: May 2005
Member: 144433 Status: Offline Thanks: 7
I havel all this, but I'm wondering, how to connect? must the phone be in OFF or ON mode? what's the exact procedure?
thanx 2 all |
You should turn the phone off, you may even want to re-insert the battery.
Before you start make sure the battery is charged to its maximum. When you're able to connect, be sure to make a full flash backup... Good luck! |
