Member: 199538 Status: Offline Thanks: 0
BH4 imposible to UNLOCK !!!
i have this phone BH41I-1AANES1
BH4 - ALCATEL and is impossible to unlock,, i hace polar ,, with the right cable with 9v battery ,,, and polar can´t detect the phono,,, I try with other cable similar,, other 9v battery, and the same things, can´t detect the phono,,, The battery on phono is Full,, the phono is turn OFF, everything is OK,, and the contacts are clean ... i try with polar, Vygin, Heinrich,, nobody detect the phone,, i try in my pc and a laptop too... Nothing What can i do ?? |
![]() ![]() ![]() ![]() Join Date: Sep 2003
Member: 39097 Status: Offline Thanks: 0
Have you ever connected another phone sucessfully with that cable?
yesss a lot of phone with that two cables
re!
If the cable is good, try on other PC ... I have this problem many times!
#5 | |
![]() As a last resort, try to remove and reinsert the battery, then QUICKLY connect the cable and try to read the phone with your software. Good luck! |
i try with other 9v battery,, direct 9v alimentation,,, turn on and off the phone,, and nothing
all that happend is that when your click to conect the phone turn ON |
#7 | |
re!
The same problem ... try on other PC! Use another software too!
PS - have you installed some Bluetooth or IR stuff to your PC ? |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2004
Member: 85387 Status: Offline Thanks: 63
so whats solution to unlock this model
#10 | |
Member: 175544 Status: Offline Thanks: 47
![]() ![]() ![]() ![]() Join Date: Apr 2005
Member: 136220 Status: Offline Thanks: 22
bh4 unlock avec veygis kraked
test moi100/100 et en plus
![]() ![]() Join Date: Jan 2006
Member: 224346 Status: Offline Thanks: 0
Check cable and unlock whit Vygis
![]() Join Date: Jun 2005
Member: 152553 Status: Offline Thanks: 0
i dont heve ithe lihgte in my phone where is't the selotion
![]() ![]() ![]() ![]() Join Date: Mar 2006
Member: 248353 Status: Offline Thanks: 2
use unibox + vygis cracked
![]() ![]() ![]() ![]() ![]() Join Date: Sep 2007
Member: 599037 Status: Online Thanks: 749
i also hav the same problem... using vygis ans even all the softwares in the usr.. but cant connect to the fone...vygis says that fone not respond..what shud i do
