12-22-2005, 14:14 | #1 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Slovakia BA Age: 51
Member: 25110 Status: Offline Thanks Meter: 79 | Step by Step unlocking and flashing K608i Red CID49 01. connect the phone in to the cable 02. select "Boot type" as "Normal boot, any CID, use TP" 03. connect GND to TP and press "Attach to phone" 04. wait until "Disconnect the testpoint!" message 05. wait for booting the phone 06. again connect GND to TP and press "convert phone in to Brown CID49" 07. wait until "Disconnect the testpoint!" message 08. now phone is Brown CID49 and we do not need TP anymore 09. select "Boot type" as "Normal boot" and press "Attach to phone" 10. do "Repaire EROM" 11. now you can do direct unlok if you want or start flashing as others SE (main flash + raw flash + customization) 12. you have to use brown CID49 flash files of course 13. press "Turn off phone" and that is all Enjoy :-) Foony Connecting via UC-10 Universal Cable... Connect the testpoint! Powering on the phone... Baseband chip ID: 0x7100 Protocol version: 3.1 Baudrate = 460800Bd Trying recovery applet... Sending applet prologue... Disconnect the testpoint! Sending applet body... Time spent entering bootstrap: 6s Initializing phone hardware... Flash manufacturer: ST Microelectronics Flash ID: 0x200D OTP Security Level: 1 (Retail) OTP CID: 49 Phone hardware initialized OK Defeating RSA protection... Defeated! Sending applet... Flash manufacturer: ST Microelectronics Flash ID: 0x200D OTP Security Level: 1 (Retail) OTP CID: 49 Analyzing configuration... Reading primary certificate... Primary certificate CID: 49 Primary certificate color: Red Reading secondary certificate... Secondary certificate CID: 36 Secondary certificate color: Brown GDFS configuration found. OSE configuration found. TestProgram configuration not found. Analysing GDFS... Done. Defeating RSA protection... Waiting for the phone to turn off... Connect the testpoint! Should the communication hang, reinsert battery. Baudrate = 460800Bd Sending applet prologue... Disconnect the testpoint! Sending applet body... Defeated! Sending applet... Replacing primary certificate... Certificate replaced successfully. Turning off phone... Phone automatically detached. Connecting via UC-10 Universal Cable... Powering on the phone... Baseband chip ID: 0x7100 Protocol version: 3.1 Baudrate = 460800Bd Sony Ericsson phone detected. Phone CID: 49 Phone color: Brown Flash certificate: A1_DB2000_49_BROWN Trying Brown CID49 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 2s Initializing phone hardware... Flash manufacturer: ST Microelectronics Flash ID: 0x200D OTP Security Level: 1 (Retail) OTP CID: 49 Phone hardware initialized OK Analyzing configuration... Reading primary certificate... Primary certificate CID: 49 Primary certificate color: Brown Reading secondary certificate... Secondary certificate CID: 36 Secondary certificate color: Brown GDFS configuration found. OSE configuration found. TestProgram configuration not found. Analysing GDFS... Done. Preparing to program flash... Programming flash... Time: 00:00:04 Flash process done. Reading security zone... Unlocking phone... Recalculating CRCs... Phonecode: 0000 (default) Turning off phone... Phone automatically detached. Connecting via UC-10 Universal Cable... Powering on the phone... Baseband chip ID: 0x7100 Protocol version: 3.1 Baudrate = 460800Bd Sony Ericsson phone detected. Phone CID: 49 Phone color: Brown Flash certificate: A1_DB2000_49_BROWN Trying Brown CID49 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 2s Initializing phone hardware... Flash manufacturer: ST Microelectronics Flash ID: 0x200D OTP Security Level: 1 (Retail) OTP CID: 49 Phone hardware initialized OK Analyzing configuration... Reading primary certificate... Primary certificate CID: 49 Primary certificate color: Brown Reading secondary certificate... Secondary certificate CID: 36 Secondary certificate color: Brown GDFS configuration found. OSE configuration found. TestProgram configuration not found. Analysing GDFS... Done. Flash file: "K600i_CXC1250014_EU1_R2T002_Brown49.ck6sw" Waiting for flash file to load... Reading phone RSA certificate... Preparing to program flash... Programming flash... Time: 00:08:06 Flash process done. Flash file: "K600i_CXC1250017_EMEA2_R2T002_Brown49.ck6fs" Waiting for flash file to load... Reading phone RSA certificate... Preparing to program flash... Programming flash... Time: 00:02:56 Flash process done. Waiting for the phone to turn off... Should the communication hang, reinsert battery. Baudrate = 460800Bd Sending applet prologue... Sending applet body... Sending CS applet... Initializing CS applet... Starting up GDFS service... Starting up filesystem, please wait... Building customization... Customizing phone... Done. Writing CDA Article MS string... Done. Writing CDA Version MS string... Done. Writing Default Article MS string... Done. Writing Default Version MS string... Done. Writing langpack string... Done. Writing country... Done. Uploading certificates... Certificates uploaded successfuly. Turning off phone... Phone turned off. Phone automatically detached. Connecting via UC-10 Universal Cable... Powering on the phone... Baseband chip ID: 0x7100 Protocol version: 3.1 Baudrate = 460800Bd Sony Ericsson phone detected. Phone CID: 49 Phone color: Brown Flash certificate: A1_DB2000_49_BROWN Trying Brown CID49 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 2s Initializing phone hardware... Flash manufacturer: ST Microelectronics Flash ID: 0x200D OTP Security Level: 1 (Retail) OTP CID: 49 Phone hardware initialized OK Analyzing configuration... Reading primary certificate... Primary certificate CID: 49 Primary certificate color: Brown Reading secondary certificate... Secondary certificate CID: 36 Secondary certificate color: Brown GDFS configuration found. OSE configuration found. TestProgram configuration not found. Analysing GDFS... Done. Turning off phone... Phone turned off. Phone automatically detached. Last edited by foony; 12-22-2005 at 17:29. |
12-22-2005, 14:41 | #3 (permalink) | |
Freak Poster Join Date: Mar 2004 Location: Behind Enemies Lines;)@Jungle Age: 44
Member: 58608 Status: Offline Sonork: 100.87163 Thanks Meter: 54 | Quote:
good work Foony thxx wbr BAYOO | |
12-22-2005, 15:01 | #4 (permalink) | |
Member: 25110 Status: Offline Thanks Meter: 79 | Quote:
01-04-2006, 22:41 | #6 (permalink) |
Freak Poster Join Date: Aug 2005 Location: USA Age: 41
Member: 167428 Status: Offline Thanks Meter: 2 | Doesn't work for me I'm trying the same step It doesn't work for me. I have W608i from Cingular. I selected "Model K608i", "normal boot, any CID, use TP" Here is my log: Version 7.15 beta ready! Connecting via Fighter USB Cable... Connect the testpoint! Powering on the phone... Baseband chip ID: 0x7100 Protocol version: 3.1 Baudrate = 460800Bd Trying recovery applet... Sending applet prologue... Disconnect the testpoint! All threads terminated. What is the problem? Here is the testpoint I used |
01-04-2006, 23:21 | #8 (permalink) |
Freak Poster Join Date: Nov 2005 Location: Albania
Member: 200804 Status: Offline Thanks Meter: 0 | Try selecting normal boot.Make the tespoint when software ask and dont realease till it says to do so.You should release it as soon as possibile when software tells you.Post the log here. BR |
01-05-2006, 00:04 | #9 (permalink) |
Member: 167428 Status: Offline Thanks Meter: 2 | Here is the log with model:K608i, normal boot Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x7100 Protocol version: 3.1 Baudrate = 460800Bd Sony Ericsson phone detected. Phone CID: 49 Phone color: Red Flash certificate: A1_DB2000_49_RED Trying Red CID49 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 1s Initializing phone hardware... Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 49 Phone hardware initialized OK Defeating RSA protection... Waiting for the phone to turn off... Connect the testpoint! Should the communication hang, reinsert battery. All threads terminated. |
01-06-2006, 16:49 | #11 (permalink) |
Major Poster Join Date: Sep 2004 Location: Philippines Age: 49
Member: 81674 Status: Offline Thanks Meter: 2 | try this for a shorter procedure: http://www.tapgsm.com.ph/showthread....454#post170454 |
01-06-2006, 17:16 | #13 (permalink) |
Member: 200804 Status: Offline Thanks Meter: 0 | Phones with intel flash chip have glue on test point so you should clean it before making tespoint and not all have the same tespoint.Look on it and you will see it is covered by protecting glue. BR |
01-21-2006, 18:49 | #15 (permalink) |
Member: 167428 Status: Offline Thanks Meter: 2 | Frustrating...very Frustrating... After strugling to get the K608i unlocked, Cruiser team now released the version 8.0 with the no TP for CID49....(never too late) Unfortunally for me the phone now doesn't seem to get to unlock. Here is my log: Version 8.00 alpha ready! Connecting via UC-10 Universal Cable... Powering on the phone... Baseband chip ID: 0x7100 Protocol version: 3.1 Baudrate = 460800Bd Sony Ericsson phone detected. Phone CID: 49 Phone color: Red Flash certificate: A1_DB2000_49_RED Trying Red CID49 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 2s Initializing phone hardware... Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 49 Phone hardware initialized OK (now I go to secutity tab and press replace certificate to CID49 Brown) Preparing to program flash... Programming flash...(it freezes for about 15 sec.) Error flashing block at address: 0x215F0000 Phone automatically detached. Ok now...What's the deal??? Anybody please help. |
Guide: How to Activate SETOOL Step by Step | shahzaadbutt | SETool2 | 66 | 06-15-2023 11:12 |
step by step how to flash W550i CID49 | jignesh_1000 | HWK | 11 | 03-11-2011 14:01 |
k750i And k608i red cid49 unlock info with out TP | Irfangk786 | Cruiser Suite | 20 | 10-11-2007 13:03 |
K608i CID49 Brown/Red/Blue step by step | Lucky7Napoleon | Cruiser Suite | 41 | 11-20-2005 23:35 |
can usb smart unlock and flash K608i ? | Flash0r | SonyEricsson (USB-Smart) | 0 | 11-17-2005 14:08 |
