| Motorola Hardware Repair Section here all threads Related to Motorola Hardware Servicing and Repairing. |
![]() ![]() ![]() ![]() ![]() Join Date: Jun 2004
Member: 68983 Status: Offline Thanks: 47
v3 insert sim
motorola v3 insert sim somebody can answer
![]() ![]() ![]() ![]() Join Date: Nov 2004
Member: 93240 Status: Offline Thanks: 0
Look at manual, if you can understand, it will help you
![]() B.R. LoopyTT |
![]() ![]() ![]() ![]() ![]() Join Date: Feb 2005
Member: 115826 Status: Offline Thanks: 6
Change the ribbon flex
![]() I know that sound stranger but work on me once time
![]() Join Date: Jul 2005
Member: 159633 Status: Offline Thanks: 0
ı change flex but not read simcard how question
Member: 14468 Status: Offline Thanks: 13
check if is water damage
if not rehot neptune and power ic check with ohmmeter resistance between sim pins ang gnd post result best regards vali |
![]() Join Date: Aug 2004
Member: 78849 Status: Offline Thanks: 0
plz explain how to repair by using good picture of the phone panel or board.use a pen to show the connections so that we can benefit from u.
thanks. |
Member: 120740 Status: Offline Thanks: 0
anyone have manual for v3x and v3i
thanks |
#8 | |
![]() Join Date: Sep 2004
Member: 83031 Status: Offline Thanks: 0
i check all rehot but still dosn't have a solution any one can help me please ??
#9 | |
| The Following User Says Thank You to Amartt For This Useful Post: |
is not soft problem
is a recurent failure in this model i check all in the scheme aparently it's all ok but still have the INSERT SIM on the screen i have 4 v3 in this condition |
![]() ![]() ![]() ![]() Join Date: Oct 2005
Member: 189855 Status: Offline Thanks: 9
V3 has sim card protection diodes also some under metal cover use service manual to find and simply remove them.
V3 will work. i have solved this problem my v3 was water damige and my fault was clear when i remove protection resistor undr metal cover. |
![]() ![]() ![]() ![]() Join Date: Jul 2004
Member: 72951 Status: Online Thanks: 10
Do you have pic of this diode?
#14 | |
In red box diode remove this is under metal cover i think check by your self. Last edited by smr29126; 08-29-2007 at 19:26. |
#15 | |
thanks !! problem solved in 2 v3
| The Following User Says Thank You to Masta666 For This Useful Post: |
