| Motorola Hardware Repair Section here all threads Related to Motorola Hardware Servicing and Repairing. |
#16 |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2004
Member: 85387 Status: Offline Thanks: 63
do you have any solution for same problem in a835
| The Following User Says Thank You to waleed2 For This Useful Post: |
#17 |
iam waiting solution for this problem please soon
#18 |
where is best friends tell me any word
#19 | |
![]() ![]() ![]() ![]() ![]() Join Date: Jul 2004
Member: 73674 Status: Offline Thanks: 21
thanks br |
#20 |
![]() ![]() ![]() ![]() Join Date: Feb 2005
Member: 117968 Status: Offline Thanks: 0
check the path with your DMM meter....
hi.
be sure that the phone are not corroted with any liquid solution... the path are goes to the CPU at the ends but u may reworks the simcard reader or can reflow the power ic under the casing... it is possible the broken contact found in v3 models.. so the DMM would help. |
#21 |
Member: 229576 Status: Offline Thanks: 1
V3 with INSERT SIM because of water damage. Removed YR1412, 2030, C707 and 700. Worked for me!!!
#22 |
![]() ![]() ![]() Join Date: Dec 2005
Member: 209570 Status: Offline Thanks: 0
can you take pictures of those components please...thanks
#23 |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2006
Member: 320363 Status: Offline Sonork: 100.1578853
my l6 water damag ok but batt not valid plz help me on mehul_patel163@yahoo.com
#24 |
![]() ![]() ![]() ![]() Join Date: Sep 2005
Member: 182216 Status: Offline Thanks: 13
best solution for insert sim on v3
change the sim reader ic filter check if liquid damage and clean contacts,reflow the sim reader.... |
#25 |
![]() ![]() ![]() Join Date: Nov 2004
Member: 91936 Status: Offline Thanks: 0
Thanks smr26126... your solution worked, I removed the resistor and the phone worked perfectly after that. As a note, the phone was previously water damaged, but this still fixed it!
#26 |
![]() ![]() Join Date: Oct 2005
Member: 194688 Status: Offline Thanks: 0
Further help needed
#27 |
![]() ![]() ![]() ![]() Join Date: Mar 2006
Member: 244008 Status: Offline Thanks: 1
thankx for the solution
sheggmat |
#28 |
![]() ![]() ![]() Join Date: Jan 2004
Member: 48552 Status: Offline Thanks: 12
Hello,
I have one V3 with this problem(insert sim). I wnated to try the solution provided by you, but when i looked under the metal cover the svchematic doesnt match the phone. It is a little bit diffrent. On the left there are tree CXXX. Two placed horizontally (on schematic only one placed horizontaly) and one placed vertically(missing on chematic). Next to it there is vertically positioned DIODE. Is that the one i have to remove? Is there another schematic for my version of the V3? EDIT: I have decidet to remove the DIODE on my own risk and NOW THE PHONE IS WORKING!! THANK YOU VERY MUCH. One more thing: Now the phone writes - INVALID BATTERY. Is this a separete problem or it is because I removed the DIODE? |
#29 |
the schematic didn't match my phone either... resistors were on the board that didn't show up on the schematic... i just guessed at which one it was approximately by eyeballing the picture and matching it to the phone... looks like i guess right, because it fixed the problem.
I don't have the phone with me, nor do i remember which one it was... but i'm sure you'll figure it out. |
#30 |
hi I need jumper for v3 power ic because It doesn't have power ic on board.Regards bye
