Old 07-08-2001, 17:11   #1
brittnee
Member: 2084
Post alcatel club DEAD
i've heard that the way to repair dead alcatel is to flash it again with a working file, should this be of the same version?
but my problem is i can't read nor write the flash with andromenda!!
thanks
Old 07-08-2001, 23:18   #2
hek
Member: 4175
Post
take good alcatel,connect it and read it with Andromeda.Then connect the dead one and flash it.
some time i succed some times not
good luck.
Old 07-09-2001, 05:24   #3
acyl2000
Super Moderator
acyl2000's Avatar
Member: 1922
Sonork: 100.64645
Cool
you must comfirm that your phone is sw or hw problem, if hw problem then you can't flash it with andromenda, after you change the I/C than your phone should be ok.
Power I/C: 02CJH8T/PTWL2207A.
Old 07-10-2001, 00:04   #4
neb
Member: 751
Post
Hi Brittnee,
Hi Brittnee,
Dead Alcatel BE1 can be revived by using Zulea's Service Software, such as v11.8, 12.3 or the special version for 16D's, eventhough they are primarily intended for unlocking...
Their are cases also of dead alcatel BE1 which is caused by wrong flashing...Mihnea's Repairer is very good for this..
But since your phone doesn't respond with Andromeda, (assuming you got good batteries)...I presumed you got a hardware problem..Check the two fusible resistors, sometimes colored blue at lower left portion of the board at board's battery terminal side, this usually get "open".
If it is intact.. I'll go with acyl2000 the IC PTWL2207A might be defective.....If you can't locate the said resistor mail me.
Regards,
neb
Old 07-10-2001, 09:06   #5
acyl2000
Super Moderator
acyl2000's Avatar
Member: 1922
Sonork: 100.64645
Agree that solution.
Old 07-20-2001, 03:56   #6
nokya
Member: 5364
Post
PTWL ic is most likely the problem 99.99%
Does anyone know where i can buy them new?I need +/- 400pcs
Old 07-29-2001, 12:31   #7
eureka8888
Member: 4675
Post
i also have this problem, phone not detected by andromeda, <br />1) i connect a working phone, ot easy,read the phone(it's imei appears on screen)<br />2) remove the working phone and place the non working phone(alcatel club),<br />3) read flash, then appears "check bat"<br />is this hardware problem?<br />thanks
Old 10-17-2001, 23:46   #8
hek
Member: 4175
Post
can any one tell me where PTWL ic is located.
Page generated in 0.08705 seconds with 6 queries
