| Siemens Hardware Repair Area all about Hardware Repairing you can get if here. |
#46 |
Member: 302395 Status: Offline Thanks: 2
need al21 solution for bad cut phone is not charging and no chance of powering on please help
#47 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2006
Member: 250468 Status: Offline Sonork: 100.110362
I still need also solution for bad cut AL21 phone is in insert sim state even sim inserted.
#48 |
![]() ![]() ![]() ![]() Join Date: Aug 2004
Member: 78028 Status: Offline Thanks: 403
i have a m55 bad cut any one have the solution now set will not accept sim card only insert sim card..
#49 |
Member: 68784 Status: Offline Thanks: 0
I need siemens C65 mobile phone schematic circuit diagram to enable me effect repair on same which we tried to cut but the interface of the cutting point , and we lost the power the phone.
#50 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2005
Member: 146708 Status: Offline Sonork: 100.108221
hi all.. anyone test this solution..? and what is this..?
![]() I have a soluiton that removing cpu and short cut to sim reader 6th pin..is there any solution except removing cpu..? |
#51 |
Member: 22893 Status: Offline Thanks: 56
@Pandemonio100;
do you have any solution about sx1 repair test point for cut method |
#52 |
![]() ![]() ![]() ![]() Join Date: Oct 2005
Member: 194907 Status: Offline Thanks: 1
need m55 v11 bad cuttest point no network repair tp helllp
#53 |
Member: 68330 Status: Offline Thanks: 15
AL21 bad test point solution needed
#54 |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2006
Member: 416908 Status: Offline Thanks: 0
| The Following User Says Thank You to dagos For This Useful Post: |
#55 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2005
Member: 172434 Status: Offline Thanks: 1
cf62 is still ver problematic after cutting, getting insert sim
#56 |
Member: 221490 Status: Offline Thanks: 1
#57 |
#58 |
![]() ![]() ![]() ![]() ![]() Join Date: Oct 2005
Member: 189506 Status: Offline Sonork: 100.1576871
ax repair after repair test point,Network does't stable
#59 |
sorry..
AX72 repair after repair test point,Network does't stable |
#60 |
![]() Join Date: Apr 2007
Member: 484288 Status: Offline Thanks: 1
A65
Hi Chris02
After cut and unlock of two cellular A65, the " green or yes " key is not working and it take of the phone when i press " yes or ok " to confirm Please what is exactely the solution Urgent. |
