Go Back   GSM-Forum > GSM Mobile Brands -Software Area- > Siemens-Benq > Siemens Hardware Repair Area
Siemens Hardware Repair Area all about Hardware Repairing you can get if here.
Old 04-12-2007, 00:20   #61
moimeme
Member: 484288
Hi Chris02
After cut and unlock of two cellular A65, the " green or yes " key is not working and it take of the phone when i press " yes or ok " to confirm
Please what is exactely the solution
Urgent.
Old 04-12-2007, 20:03   #62
moimeme
Member: 484288
Please have you got the scematic of the the A65, because i have the same problem with the green or ok key
Thanks
Old 05-01-2007, 01:28   #63
ParsaMobile
Member: 267503
dear sir
i also have this problem.
after unlocking by tp and sst program i cant use this phone.
when i power on the phone i should push left key over green botton ( aerocheck ) to use but this key is not working.
i know its my fault by bad test point cut , but what is the solution without replace cpu ???
please show a solution with a picture for A65.
thankyou very much and for everything
Old 05-01-2007, 14:58   #64
dagos
dagos's Avatar
Member: 416908
Originally Posted by ParsaMobile View Post
dear sir
...go to http://forum.gsmhosting.com/vbb/show...=266494&page=2
dagos
Old 05-03-2007, 19:17   #65
gsmxpert
gsmxpert's Avatar
Member: 172434
this one is working well for cf62
Old 05-28-2007, 19:51   #66
rayen
Member: 235606
c 65 is dad hawt the solution of repair , help me
Old 06-08-2007, 18:22   #67
.:==di@bila==:.
.:==di@bila==:.'s Avatar
Member: 254137
C72 dead after bac cut, please repair mode needed.
Old 07-07-2007, 16:51   #68
tolski
tolski's Avatar
Member: 34750
Originally Posted by SNSOFTKILLER View Post
I still need also solution for bad cut AL21 phone is in insert sim state even sim inserted.
we have the same problem mate..hope someone can share solution here..thanks
Old 08-03-2007, 18:13   #69
libra202
Member: 173206
Use "SEARCH" .....
I found the solution single putting what needed in the box
"SEARCH"
example "insert sim al21"
Regards
Old 09-07-2007, 10:41   #70
market_3b2002
market_3b2002's Avatar
Member: 89177
Phone Ax72 bad cut , I tried to repair under the pic but the phone is the same nothing change
Its stay stuck to orange siemens
Are two peaces new ones the same problem
Advice??
Thank you
Old 09-08-2007, 17:17   #71
market_3b2002
Member: 89177
Sems the ax72 pic solution showed before is the solution for the network and not for the other bad cat solution...
Any advices or siem ax72 diag pic
Thank you
Old 10-15-2007, 00:34   #72
moussa djamel
moussa djamel's Avatar
Member: 296018
cf110 insert sim card after bad cut, please repair mode needed
Old 10-16-2007, 08:49   #73
imran zafar
imran zafar's Avatar
Member: 328187
Sonork: MBDin.fleeforum.com
A65 No Network After Flashing At Sst5.32 Creck Any Solution
Old 10-28-2007, 11:33   #74
a mobile zone
Member: 575719
thanksdsssssssssssssssssssssssssssssssssssssssssss
Old 10-29-2007, 18:07   #75
Tadiwa
Tadiwa's Avatar
Member: 46042
Sonork: 100.1575650
Am i wrong
Originally Posted by dagos View Post
i dont see any tp repair diagram for al21 someone post something useful
Page generated in 0.11246 seconds with 7 queries
