![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2001
Member: 3194 Status: Offline Thanks: 1
Any help??
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 1999
Member: 596 Status: Offline Sonork: 100.33096
Hello<br />You should try to flash it at first <img src="smile.gif" border="0">
i ll try it..
thx |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2002
Member: 12724 Status: Offline Thanks: 1
I have same problem.I can flash it.But when press pwer on switch just TOP LED goes on.
When I connect charger, (even when board is not attached to battery) LED goes on and nothing |
That's mean your flash file incorrect , 600 has two hardware version, you have to change your flash file!
@Bert
How to flash Sgh 600?
When i try using turbo downloader, always said NACK Receive times 0.0 Why ?? pls help rgds |
![]() ![]() ![]() ![]() ![]() Join Date: Apr 2000
Member: 1191 Status: Offline Thanks: 22
hi guys.
but this problem is possible not only SW ! one friend have sgh-600, phone work normaly but the friend use glue on display to connect to PCB. after removing glue phone stop work and now have some problems like GSMLight. i tink that problem is HW. @CellM@n what you make with your sgh-600 1st: flash it or repair HW problem ? regards Svetli |
Member: 10981 Status: Offline Thanks: 0
%60 13 mhz crytal fail
![]() ![]() Join Date: Sep 2002
Member: 15650 Status: Offline Thanks: 0
13MHZ damaged or sometimes damage eeprom IC
![]() ![]() ![]() ![]() ![]() Join Date: Jun 2001
Member: 5072 Status: Offline Thanks: 0
try to remove the lcd and them power it up ...in more than 50% of cases it works...
Also check battery connector .."+" and "-"..check for shorting ...sometimes the charging connector gets short...and as a result the set gets dead. The 3rd and most reliable things to do ...is check and change the fillowing Eeprom CPU (very important) and 13Mhz crystal. Rgds, themobileking |
