02-18-2006, 14:57 | #1 (permalink) |
Freak Poster Join Date: Dec 2001 Location: clock wise Age: 48
Member: 7845 Status: Offline Thanks Meter: 3 | ust 1.05b not work pls. waitt loading modules frezee or loading modules and close but 1.02 working how to solve this problem thx B R |
02-18-2006, 16:20 | #2 (permalink) |
Banned Join Date: Nov 2001 Location: IRAN Age: 38
Member: 7444 Status: Offline Sonork: 100.99999 Thanks Meter: 10,013 | Loading Module and close or Freeze , 100% Chinese or so on Codepage. see here to solve it : http://forum.gsmhosting.com/vbb/showthread.php?t=268723 |
02-18-2006, 16:23 | #3 (permalink) | |
Insane Poster Join Date: Aug 2002 Location: tripoli libya Age: 54
Member: 14663 Status: Offline Thanks Meter: 6 | Quote:
B.R | |
02-18-2006, 16:43 | #4 (permalink) | |
B.R | |
02-18-2006, 18:57 | #5 (permalink) |
Freak Poster Join Date: Nov 2001 Location: oi
Member: 7368 Status: Offline Thanks Meter: 51 | yes, this solution solves UST2_105 startup problem, but now my russian version of Windows is unusable, windows can't find files with russian names, programm buttons like ?????????? |
02-19-2006, 00:09 | #6 (permalink) |
Crazy Poster Join Date: Jul 2005 Age: 44
Member: 164812 Status: Offline Thanks Meter: 0 | ust_105b causes bluescreens and pc-crashes everytime. i dont want to change system to us-english, i think this is a problem of ust not of my os. it has to work with every language, not only with us-english!!! |
02-19-2006, 11:47 | #7 (permalink) |
Freak Poster Join Date: Aug 2002 Location: Poland / Kolbuszowa Age: 43
Member: 14277 Status: Offline Thanks Meter: 2 | i've got same problem.... version 1.02 works great but 1.05b freezing or closing at startup.... it's UST BUG so remove it because i dont whant change regional setting because have problem after change... br orcgsm |
02-21-2006, 00:35 | #9 (permalink) |
Freak Poster Join Date: Jul 2005 Location: Poland, Tarnów Age: 39
Member: 159960 Status: Offline Thanks Meter: 2 | I have "Change Interface Language" on startup and aplication is shutting down or hanging up. What to do?? When I delete ust.cfg file, then I starting aplication and I choose English, but after that aplication shutting down or hang up... Older version 1.02 work good. Please help urgent!! |
02-21-2006, 11:49 | #10 (permalink) |
Member: 7444 Status: Offline Sonork: 100.99999 Thanks Meter: 10,013 | its normal, when you press change interface language it close ust and delete UST.CFG and when you start again you will be asked to select lng. its norma. |
02-21-2006, 17:31 | #11 (permalink) |
Junior Member Join Date: Jul 2004 Age: 46
Member: 71051 Status: Offline Thanks Meter: 0 | VAHID i want work in windows thith russian regional settings i think you can made it in you programm in first our programm i have some problems but in new programm i dont want have ANY PROBLEMS WHITH REGIONAL SETTINGS iwant stable and good workin programm for my money!!!!!!!! |
02-21-2006, 20:15 | #12 (permalink) |
Member: 159960 Status: Offline Thanks Meter: 2 | I know that, but when I choose language and after that aplication says change interface language. When I run aplication again, it again says change interface language, after that shuting down or hanging up, and all the time when I run aplication. What to do? What can I do to solve this problem?? P.S. I use the cruiser on the same computer. |
ust pro 11 not work with | Fonefingz | UST Pro II | 1 | 08-11-2007 23:24 |
ust support is not working any other link for downloading file | aukonline | UST Pro II | 1 | 07-04-2007 18:37 |
ust-pro2 acount not working properly | kanwal | UST Pro II | 1 | 06-03-2007 11:22 |
Ust c140 cable not working | miandad | UST Pro II | 9 | 05-20-2007 10:52 |
ust 5.4 not working to repair system failure when i write eeprom | tcteam | Samsung Flashers, Software, Firmware. | 1 | 02-04-2004 23:10 |
