Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Direct Codes ★ | Direct Unlock Source | Mark Forums Read |
02-22-2006, 13:41 | #1 (permalink) |
No Life Poster Join Date: Aug 2001 Location: Madrid (from here to heaven) Age: 42
Member: 6084 Status: Offline Thanks Meter: 4 | SOLUTION to "Bad connection, check your test point" Check if RJ45 that connects to testpoint PCB have 5 wires. First 4 (2, 3, 6, 7) goes straight to tp's. Last wire (mine black), pin 8 is GND. Connect this pin to phone's GND. Now, you should have good conection, tested on C2-3m, with soldered wires to phone's PCB. |
03-01-2006, 17:49 | #3 (permalink) |
No Life Poster Join Date: Apr 2002 Location: South Spain Age: 41
Member: 10905 Status: Offline Thanks Meter: 109 | Thanks mate, it seems you´re cleverler than SWS team, they only know to say: If proceces stops at 20% is 100% testpoint problem.... Now is working for me too. Thanks again m8 |
03-06-2006, 00:25 | #4 (permalink) |
Junior Member Join Date: Jan 2006
Member: 220412 Status: Offline Thanks Meter: 0 | carissimos colegas de trabalho pois aqui no brasil estamos passando por um gravissimo problema desses, muita gente que adquiriu o produto sws-sag ao trabalhar os atc, sempre da esse erro e ninguem conseguiu desvendar esse misterio. cassop alguem possa nos ajudar, desde ja gratos |
03-06-2006, 01:31 | #7 (permalink) |
Member: 220412 Status: Offline Thanks Meter: 0 | colleague I am searching information to who can help me, I am passing for this problem of test point here. e I am in brainstorming since ja grateful. ha I am Brazilian and naum I say to almost nothing in outr language |
03-06-2006, 05:59 | #8 (permalink) |
No Life Poster Join Date: Jan 2005 Location: anywhere there is freedom Age: 47
Member: 106700 Status: Offline Thanks Meter: 47 | so u mean the key is the 5th wire which is ground because apart from that, i don't see what news the this thread? . i have a v56 which always stop at 40 %. i usually do not have problem working with tp and but this one, despite having try several times to solder tp again and again, it is still stopping at 40 % (hash 45 00 01). can somebody help? thks ashvin |
03-06-2006, 09:24 | #9 (permalink) | |
No Life Poster Join Date: Sep 2002 Location: Türkiye Age: 48
Member: 15880 Status: Offline Sonork: 100.1612155 Thanks Meter: 452 | Quote:
Searching Phone..Found. Reading Phone Info : BAD CONNECTION CHECK YOUR TEST POINT!!! - Phone Firmware : 5102360587904 KB3,ZF: 040705 1605 - Phone Imei: 356107003084996 - Hash Table : 84 08 01 - Phone Code : 00000000 i have lasted version from sws SwS_SaG_BoX_UPDATE_240206B_NO_PR_INS and i have same problem | |
03-26-2006, 14:56 | #13 (permalink) | |
Freak Poster Join Date: May 2005 Age: 54
Member: 145807 Status: Offline Thanks Meter: 4 | Quote:
03-26-2006, 23:37 | #15 (permalink) |
Freak Poster Join Date: Jun 2005 Age: 49
Member: 152153 Status: Offline Thanks Meter: 19 | problem unlock sagem Searching Phone..Found. Reading Phone Info : BAD CONNECTION CHECK YOUR TEST POINT!!! - Phone Firmware : 5102360577904 KB3,ZF: 040705 1605 - Phone Imei: - Hash Table : 84 08 01 - Phone Code : 00000000 |
Thread Tools | |
Display Modes | |
Solution For : BAD CONNECTION CHECK YOUR TEST POINT!!! | hitibiti | SwS_SaG_BoX | 10 | 04-02-2007 09:26 |
what happen SwS-Sag box,used display BAD CONNECTION CHECK YOUR TEST POINT!!! | kkio | SwS_SaG_BoX | 24 | 05-15-2006 12:13 |
myx7.. bad connection check your test point | CHAPRAN | Redbox | 3 | 02-23-2006 08:12 |
MYC2-3 always " BAD CONNECTION CHECK YOUR TEST POINT!!!" | CyberKareca | Redbox | 8 | 12-25-2005 11:35 |
Bad Connection Check Your Test Point | .:bono:. | Redbox | 0 | 12-21-2005 02:27 |
