Old 02-20-2002, 21:45   #1
joe locks
Member: 6689
Post alcatel db dead
i have a few alcatel db that are dead i reflowed the entire board but no joy any ideas will be appreciated
Old 02-21-2002, 09:46   #2
jonwillow
Member: 461
Post
Try check all resistors in power area.<br />If you have software problem, use SW Alcatel repairer.<br />You can't read phones with any sw ??<br />
Old 02-22-2002, 05:30   #3
Williamcwy
Member: 8898
Please replace Power IC, sure ok one...
Old 02-23-2002, 18:15   #4
sidharthaharish
Member: 7176
hai friend <br />follow these steps<br />1 first find whether its a hardware or software problem....if the resistance between the positive and negative terminals is less than 1000ohms its hardware complaint...you have to replace power ic....if you dont have power ic with you, you can try shorting pin number 2 and 3 of power ic...the phone will be ok....<br />2 if its a software problem use be1srv12.3to cure your phone...90%phone will be cured.. <br />3 if not cured the best software is andromeda5.9..try the user default option in it..if not cured you have to flash the phone using andromeda with correct version...<br />best of luck and please inform me about the result..<br />thanking all zfrank friends <br />sidhartha harish<br /> harish@net-city.com <img src="wink.gif" border="0"> <img src="wink.gif" border="0"> <img src="wink.gif" border="0"> <img src="wink.gif" border="0"> <img src="wink.gif" border="0">
Old 02-23-2002, 19:13   #5
makgsm
Member: 6462
Post
i have four alcatel be4 dead
idon't know what's the pb
i selled with this pb
Old 03-01-2002, 03:53   #6
MobileSoft
MobileSoft's Avatar
Member: 3355
Dead Alcatels
All dead alcatel wit hardware problem, usually PTW IC (Powerchip).
First try and short pin 2 and 3 if this not work - replace - Works most of the time!
To the South African dude who posted this msg - If u still need help or need any other help - Call me - 0827687778
Old 06-16-2002, 04:58   #7
arti123a
Member: 8537
where i find powerchip in pcb ??
alcatel db
Old 06-16-2002, 06:09   #8
ARS
Member: 2721
Is it a big IC near SIM connector
PTWL2207
Old 06-16-2002, 07:16   #9
arti123a
Member: 8537
thanks ARS !!!
Old 10-13-2002, 07:50   #10
iqballk
iqballk's Avatar
Member: 13932
short 1+2+3 pins in ptw..
Page generated in 0.08367 seconds with 6 queries
