Go Back   GSM-Forum > Product Support Sections > No More Support/Temporarily Closed > USB-Smart > Samsung (USB-Smart)
Old 03-02-2006, 10:03   #1
sjakie
Member: 847
Sam_Tool_v1.05 nothing for ZV30
V1.05 doesnt work for ZV30
Nck :0r2640
Nsck :0r4640
Spck :0r6640
Cpck :0r8640
No direct unlock.
No flashing support.
regards
Sjakie
Old 03-02-2006, 19:13   #2
dani146
dani146's Avatar
Member: 3812
Nck :0r2640
Nsck :0r4640
Spck :0r6640
Cpck :0r8640
No direct unlock.
regards
Sjakie
Working perfect in my computer... just tested.
Please contact me in privat to check what can be the problem.
Old 03-03-2006, 15:08   #3
florin35
Member: 232863
zv30 working perfect.
@sjakie: Are you shure you select correct com port?
you must select com port after you connect phone to usb port.
Old 03-03-2006, 15:32   #4
zulea
zulea's Avatar
Member: 5325
Nck :0r2640
Nsck :0r4640
Spck :0r6640
Cpck :0r8640
No direct unlock.
regards
Sjakie
v1.05 work very well (same v1.03 and v1.04), BUT:
- you have to NOT USE any Serial COM port adapter with shorted pins 2-3
(sorry, but we are not Winimei or other 3rd party craps who use parts from original software)
- you have to select USB VIRTUAL PORT number, and not the COM1 Serial port number (not like you do here, COM1, where you put 2-3 strap, even if NOBODY SAY to do that)
Next time use also your brain too, it will be more usefull for both you and us.
Best regards,
Zulea
Old 03-03-2006, 16:08   #5
sjakie
Member: 847
Hi, did not use com adapter, i use only with winimei.
I had prevouis ZV30 no problem with winimei, but this one it
wont unlock.
So few days ago i bought Smart Samung.
using USB cable that always worked with winimei, maybe not good for smart samsung ?
And using com 8.
Still get
Wait...Ok Time: 00:02s, 782ms
Read Settings
Master Control Lock 00000000
Nck :0r2640
Nsck :0r4640
Spck :0r6640
Cpck :0r8640
Done.
Old 03-03-2006, 22:39   #6
sjakie
Member: 847
ps
when you do what you say i did.
you will get
Wait...Ok Time: 00:02s, 844ms
Comunication Error
Old 03-04-2006, 12:17   #7
zulea
zulea's Avatar
Member: 5325
wont unlock.
And using com 8.
Still get
Read Settings
Nck :0r2640
Nsck :0r4640
Spck :0r6640
Cpck :0r8640
Done.
If Winimei cannot handle this phone, almost sure there is some hardware damages on your phone. From your log, RX and TX lines are SHORTED together (because what you have here - readed back - is EXACTLY what is send to phone). This was my first thinking and because of that I say about COM adapter with 2-3 pins shorted. Check phone connector, maybe damaged, or maybe your cable have problem on this phone ('chinese quality cable' maybe not fit exactly into phone connector and make short RX/TX pins).
I just tested ZV30 and all is working well with USB cable.
Old 03-04-2006, 14:41   #8
dani146
dani146's Avatar
Member: 3812
actualy it is possible that it is software fault... Your IMEI area can be
damaged. Use this samsung tool V1.05 to put original IMEI and fix your phone.
Use z500 serial cable for that. After that all will be ok
Page generated in 0.08503 seconds with 6 queries
