| (Non Nokia) CDMA/TDMA Cell Phones All CDMA & TDMA Cell Phones here, Please Note that Nokia CDMA/TDMA Related Threads are not here. |
Member: 239502 Status: Offline Thanks: 0
Hello everybody!!!
I repaire and flash mobile phones trough JTAG port. In some modeles, for example Samsung X720, X520, X430 there are TDO, TDI, TMS, TRST, TCK and TMODE pins set. I connecting to JTAG, put TMODE pin down and everythig woking correct. In Kyocera SE47 TMODE pin absent, but everything work right. In such models such Samsung V500 or E250 TMODE absent too, but when I connect to mobile JTAG don't work, as if I couldn't turned on TestMode (Setted by TMODE). Please, help me how connect to Samsung E250 (for example) using JTAG if there is no TMODE pin
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2004
Member: 98572 Status: Offline Thanks: 106
what qualcomm chip the E250 use?
what jtag device you have? |
#3 | |
For flash programming I'am using OCDemon Flash Programmer (Macraigor) and Wiggler cable |
The MSM5500 chip have tmode pin, it's located at pin b17.
Good Luck... |
#5 | |
But I haven't MSM5500 datasheet therefore I don't know where is located pin b17. Pleeassse, show me on picture which attached to post |
the dot sign on the IC indicates the pin A1
the number is horizontal and the alphbetic is vertical. so to find the pin b17 in your attached pic will be: start counting from lower right (where the dot) = A1 count 17 to left. it will be the pin A17, then move upwards 1 count will be the pin B17. that's it. Good Luck... |
#7 | |
I humbly thank you for help. JTAG IS WORKING!!! |
![]() ![]() ![]() ![]() Join Date: Jan 2001
Member: 3179 Status: Offline Thanks: 3
need simple jtag scematict
Wiggler cable here --->
Member: 15458 Status: Offline Thanks: 0
e250 jtag Flash Programmer ?
need soft prog for this
What about sw ? There are many programms work with Wiggler cable, for example OCD FlashProgrammer link: www.macraigor.com
What touchs upon e250 flash programmer - OCD FlashProgrammer I want ask every-body, may be some-body know JTAG test point for SKY7200 ? |
have msm5500.OCD and kbb05a500m flash.ini ?
Member: 249593 Status: Offline Thanks: 0
Hello!
Could you help me with answer. Where is TMODE (DBGEN) signal in motorola odm family (c155/c115) for cpu Callypso - d751749 or Panasonic GD60 phone - cpu hercrom400? I need to know how to enable their ICE logic. Thanks in advance! |
I need msm5500.OCD and kbb05a500m flash.ini two file.who can send to me
my mail: nbzhuhui@163.com xoen thanks! |
