![]() ![]() ![]() ![]() Join Date: Oct 2004
Member: 88410 Status: Offline Thanks: 0
Z140 - always communication error
Hi there
First use on the samsung and it was a z140 - no matter what i did i only got Communications error Tried different cables etc but no luck can someone provide a step by step so i can see what im doing wrong? should i be using com or usb etc etc etc cheers FWC |
#2 | |
![]() ![]() ![]() Join Date: Oct 2005
Member: 191257 Status: Offline Thanks: 0
#3 | |
![]() ![]() ![]() Join Date: Aug 2003
Member: 36951 Status: Offline Sonork: 100.63212
go to START/SETTINGS/CONTROL PANEL/PHONE AND MODEM OPTIONS double click on MODEM OPTIONS click on MODEMS. in that tab you have all instaled modems. you must REMOVE all SAMSUNG CDMA #2, #3, #.... from there and all MOTOROLA MODEM #1, #2, #..... unplug the SAMSUNG phone from usb cable and plug it again. windows will ask for drivers. instal the drivers. after that go to MY COMPUTER, right click on it, PROPERTIES/HARDWARE/DEVICE MANAGER. here go to MODEMS and there you will see SAMSUNG CDMA as modem. double click on it, select second tab MODEM and you will see the come port where the phone is instaled. select it on the software and enjoy. br |
#4 | |
![]() ![]() ![]() Join Date: Mar 2001
Member: 3812 Status: Offline Thanks: 0
Seccond - AFTER you connect phone to cable and computer you'll see a new port detected by Samsung program. Select this new port and make your job
Member: 194518 Status: Offline Thanks: 1
Many thanks this solved all my problems!!
Member: 4055 Status: Offline Thanks: 0
its possible use USB cable to flash Firmware ? i have a e730!
