Go Back   GSM-Forum > Product Support Sections > No More Support/Temporarily Closed > USB-Smart > Samsung (USB-Smart)
Old 03-07-2006, 19:19   #1
Jankovic
Jankovic's Avatar
Member: 38150
Unlocking USB-Smart and UFS3/ Twister
Hello
Today I try Unlock X660 With SAM Tool 1.06 and Choose UFS .... Phone Powered ON And Start Unlock Process But get Error TIMEOUT etc etc..... Please Check this and give advice how to ..... Try to change Speed .... Cable Is OK later phone unlocked By UFS3 .......
Mario
Old 03-07-2006, 20:19   #2
Bernie
Bernie's Avatar
Member: 45814
I have the same problem with one X640, did not work with usbsmart but with same cable unlock was fine with ufs-samtool
Bernie
Old 03-07-2006, 23:11   #3
uffehbg
Member: 212295
i have the same problem with a x460!
does samsung tool work?
Old 03-07-2006, 23:46   #4
Phantom
Phantom's Avatar
Member: 1133
Bernie
Same here. Does not work
Old 03-07-2006, 23:47   #5
Phantom
Phantom's Avatar
Member: 1133
Bernie
I get same result as Bernie.
Old 03-08-2006, 08:47   #6
easternlm
Member: 239849
take out your bettery and try again.....without it
Old 03-08-2006, 09:50   #7
dani146
dani146's Avatar
Member: 3812
Originally Posted by Jankovic
Hello
Mario
try this new release:
http://forum.gsmhosting.com/vbb/show...04#post1626604
Old 03-08-2006, 12:38   #8
Phantom
Phantom's Avatar
Member: 1133
Originally Posted by dani146
Thanks Dani for the update.
I still have problems with E700.
As a suggestion, could you please add an *ini into the proggy where your default settings will be remembered? It can be quite tedious to reconfigure the comm settings everytime you want to use the sw.
Thanks.
Old 03-08-2006, 13:22   #9
uffehbg
Member: 212295
still dont work with the x460 and x640!!!!!!!
i use 15in1 santel cables and it shold work shouldnt it?
have any one unlocked these modells?
uffe
Old 03-08-2006, 14:34   #10
dani146
dani146's Avatar
Member: 3812
Thanks.
We realy need to check why you can't work with E700.
About your suggestion - it is really a good advice.
uffe
For me is working with normal santel or any serial E700 cable or use twister A300 cable.
Old 03-09-2006, 10:05   #11
Jankovic
Jankovic's Avatar
Member: 38150
X660 problem too
Hello
Thanx For Update but problem is still there ... I use UFS3 and USB smart but same error ........
Mario
Old 03-09-2006, 11:38   #12
dani146
dani146's Avatar
Member: 3812
Hello
Mario
ahhhhhhhhhhhhhhh
Man - just check your screenshot !!!
You did not select any speed to BAUD RATE (speed on comm port)
Old 03-09-2006, 12:40   #13
uffehbg
Member: 212295
problems
this is what i get everytime!!
Presss On Or Insert Autoignition Cable
Wait...
Timeout.Repeat Operation!
after i connect phone and it is switched off! i get the message that i shold switch on the phone wituch i do!
then i get the wait.....
timeout.repeat operation!
i select the right com port wich is 6 i checked and i tried al different speeds!
what can i do
i looked in my computer and got this from my com ports:
usb data cable vcp (com6)
is that correct for the santel cables? or do i have the wrong drivers?
plz answer zuela or dani!
need help now!
Old 03-09-2006, 12:55   #14
uffehbg
Member: 212295
i have santel cables but with usb connection! does that matter?
i dont have the serial/com port one!
but i connect i get a virtual com port which is 6! and i choose that one when i connect!
uffe
Old 03-09-2006, 13:47   #15
uffehbg
Member: 212295
i forgot to say that i have the santel 15in1 tool but with usb connection not the one that you connect to your com port
Page generated in 0.10353 seconds with 7 queries
