![]() ![]() ![]() ![]() ![]() Join Date: Feb 2002
Member: 9568 Status: Offline Thanks: 1
How to connect UFS and USB Smart
Is there anyone who successfully connected USB Smart and UFSx/Twister?
Can someone give a some manual how this working? Anytime when I select UFSx/Twister software give me message connect UFSx.... Thank you for answer, WBR |
![]() ![]() Join Date: Dec 2005
Member: 206235 Status: Offline Thanks: 0
check your cable men it might be lossing... by the way what the status of the box when you connect the cable? does the red and yello light lblinks?
No, lights red and yellow just lighting... no blinking..
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2001
Member: 7741 Status: Offline Thanks: 9
strange! why there is no more answer from the replier?
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2000
Member: 847 Status: Online Thanks: 18
Hi, also cannot work with UFS tried on D500 and X640..no connection.
time out Box is recognized. With UFS box its ok.. regards Sjakie |
![]() ![]() ![]() ![]() Join Date: Jan 2004
Member: 49066 Status: Offline Thanks: 2
same probleme with me i can't connect to any mobile i try d500. e350. d410 n700. but no result. if any one can connect tell me plz. i loss 2 week with this tool. and it can't flash sony ericsson correctlly.
because it damage 1 t300i.
bad box...where is you ZULEA.
it's necessary to answer with work not with talk.
![]() ![]() ![]() Join Date: Mar 2005
Member: 126399 Status: Offline Thanks: 0
I had same problems, and then I bought the PCI-USB card and install USB smart on that card, and UFS is installed on the USB that is connected directly to motherboard.
Try that and tell me what did You do. Best regards. |
Member: 204211 Status: Offline Thanks: 13
Yes you r right milica i am using the same system and no problem.
![]() ![]() ![]() ![]() ![]() Join Date: May 2001
Member: 4600 Status: Offline Thanks: 100
I cannot connect ufs with usb smart but all ufs programs working well with ufs.
#13 | ||||
![]() ![]() ![]() Join Date: Mar 2001
Member: 3812 Status: Offline Thanks: 0
I connect Twister without problems. Olso your UFS box MUST be latest firmware version in order to work with usb-smart samsung. Quote:
You have 3 posts one after another. If you don't know, in this forum you can olso use EDIT button and add new messages... Quote:
