Go Back   GSM-Forum > GSM Mobile Brands -Software Area- > Alcatel TCL > BF, BG, TH, BHx Series
BF, BG, TH, BHx Series Alcatel BF3/4 and also BG3 series, also THx, BHx are located here.
Old 03-11-2006, 05:45   #1
Grief
Member: 41146
*** blinking
please help to find working full flash for blinkinkg *** (565) for s2gsm
Micron 8+4MB
*** v012 [___012_KW143B02]
s2gsm in ver2.60 can repair, but need working full:
WHAT'S NEW in version 2.60:
- now it's possible to repair sw problems with 3 original backup files - .sec1, .sec2 and .eep
- these backup files are automatically stored in your eeprom folder each time you connect to phone
- here is a little how to fix phone with sw problem (usually only blinks after power up):
1) write fullflash from another phone with exactly same firmware version
2) use restore backup function, switch file type to EEPROM backup files and select valid original backup file
3) use restore backup function, switch file type to SEC1 backup files and select valid original backup file
4) use restore backup function, switch file type to SEC2 backup files and select valid original backup file
5) use unlock function
- that's all - if you've used valid original backup files phone will work now
- dont ask me for any flashfiles, it's up to you to get it somewhere
- it's quite complicated and designed for skilled users only - if you have any problem with anything from above then simple dont use it
Old 03-11-2006, 17:29   #2
stepw
stepw's Avatar
Member: 39097
Did the phone start blinking after unlock attempt or died on its own?
If it died itself this method won't help as eeprom is probably corrupt.
Old 03-13-2006, 03:56   #3
Grief
Member: 41146
it died itself
you sure what "this method won't help as eeprom is probably corrupt"?
Old 03-14-2006, 05:16   #4
stepw
stepw's Avatar
Member: 39097
The backups should be taken from a working phone.
Otherwise chances are that EEPROM is destroyed and even if you write a working full flash from other phone and then write your damaged EEPROM, you will get the same blinking phone...
Page generated in 0.06281 seconds with 6 queries
