S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
03-24-2006, 23:48 | #1 (permalink) |
Freak Poster Join Date: Sep 2004 Location: Croatia / Rijeka
Member: 83831 Status: Offline Thanks Meter: 11 | C72 Unlock Tutorial (all X65, X75 Too) 1. put px75v1 java app on your phone in java/jam/games folder and run that app with data cable (original Siemens) still connected -it will calculate you Hash & ESN codes after few minutes, write them to paper P.S. If this app don't work try with px65v5 java app (both on forum for download-->search"px75v1") 2. diconnect cable & turn off mobile 3. Connect simple "china made" cable to phone & run x65PapuaUtilsV077-eng.exe (it is English version & can be found in this forum) 4. In codes tab of papua's soft write first IMEI then Hash & ESN which U got 5. Click Calc SKEY + BootKey button - after less than minute you will got SKEY & BootKey calculated 6. Phone is off ; now power on phone & while phone is booting quickly press Enter SKEY in phone button in Codes tab -If it shows something bla bla..."Factory mode" ..bla bla than you managed it right & you can go to step 7 -if doesn't show "Factory mode" repat step 6 until it works 7. Click on Freia.log button A) save dialog will appear, choose "No" & some blocks will be written to phone & phone will be unlocked B) if you choose "Yes" in save dialog it will save freia.log, and after you must create .map file from this .log with Freia and then use Siemens EEPROM tool.exe to upload map file to phone to unlock it (result is same, just more complicated, and use it only if solution A) doesn't work for some reason) |
03-25-2006, 09:45 | #2 (permalink) | |
Freak Poster Join Date: Mar 2005 Location: croatia Age: 41
Member: 129095 Status: Offline Thanks Meter: 8 | Quote:
Did u try this solution with new c72,v22 (some modification below yojstick and keyboard, inserted blue plastick piece). Im doing whithout java patcher, with TP, and get ESN, HASH, IMEI, but cant calculate S-key, (u can see on thread below). Will patcher calculate diferent ESN, HASH? | |
03-25-2006, 10:10 | #4 (permalink) |
Member: 83831 Status: Offline Thanks Meter: 11 | @nbene This is not patcher i've been talking about, it is only java app which calculates HASH & ESN. Your codes are wrong becouse SKEY can't be calculated (Why?, don't ask me). Better try java app and if you get codes you will be back in the BIZNIS ! |
03-25-2006, 12:32 | #5 (permalink) | |
Banned Join Date: May 2003 Location: www.CentralMobile.net/vbb
Member: 28188 Status: Offline Thanks Meter: 579 | Hi mates, Quote:
The method B is useless and dangerous. It is the most correct method without disassembling the phone and must be took as reference for all S-Gold. thanks for your tutotial Best regards, Aishur | |
03-29-2006, 22:22 | #6 (permalink) |
Junior Member Join Date: Mar 2006
Member: 251172 Status: Offline Thanks Meter: 0 | Hi, Just wanted to say thanks for the excellent tutorial. I recently was given a C72 but it wouldn't work on my network as it was locked to Orange. I followed the instructions and it worked like a dream! The only bit you have to remember is the last point where you click "freia.log" - click Cancel to the save dialog, then Yes in the popup that opens. Thanks once again! Shandyboy Last edited by BB-gsm; 03-30-2006 at 13:06. Reason: Removed OFF TOPIC link ! |
04-05-2006, 14:49 | #8 (permalink) |
No Life Poster Join Date: Sep 2003 Location: Dubai
Member: 39022 Status: Offline Sonork: 1575244 Thanks Meter: 94 | thanx dear now i solved my problem ur solution is 100% work just 1 thing i add , in the end when clik friea.log button than click cancel and don't save it which u show and than after cancel it show "Yes" or "No" small window, than click "Yes" button and its unlock |
04-13-2006, 13:08 | #9 (permalink) |
No Life Poster Join Date: Sep 2005
Member: 183043 Status: Offline Thanks Meter: 68 | what kind of program must i use for c72 unlocking.sst or is there a newer version of freia out that support c72 unlocking or is it the same as c65 seeing that the testpoints are the same?thanks |
04-13-2006, 13:50 | #11 (permalink) | |
Member: 183043 Status: Offline Thanks Meter: 68 | Quote:
sorry man i am soooo stupid.my fault! | |
04-20-2006, 14:03 | #13 (permalink) |
No Life Poster Join Date: Jul 2005 Location: zunZun Team Age: 43
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | @gsmspecialist2 The link for x65PapuaUtils V077_eng is: http://www.****************/siemens/x65PapuaUtilsV077.zip The pass from zip is: i-ztnawhcs Go0d LucK |
04-20-2006, 15:42 | #14 (permalink) |
Junior Member Join Date: Apr 2006
Member: 261628 Status: Offline Thanks Meter: 0 | I need a few clearification: 1. Should I do back up before doing this. 2. Why there are two cables mentioned in the original post. Siemens cable should be enough? 3. Most importantly, while I am doing this should I have old SIM inserted or new one or none? Thanks |
04-20-2006, 20:25 | #15 (permalink) |
Member: 83831 Status: Offline Thanks Meter: 11 | 1. If you are doing everything like in totorial there's no need for backup, BUT, I personally always do backup just to be shure, it doesn't cost you anything ;-) 2. Original Siemens cable is only good for uploading java app to phone and not for service jobs 3. Remove any SIM while unlocking Clear !??!? 8-P |
!!!FREE!!! New x65/x75 midlet,calc ESN & HASH in 5 secs.,compatibille with Papuas!!! | ViperGSM | S-Gold Based Phones | 33 | 11-24-2006 19:09 |
x65..x75 PapuaUtils Lite v1.3 | schwantz | S-Gold Based Phones | 27 | 08-29-2006 12:49 |
Bootcore fixing and repairing of the "Beeping problem" for X65/X75 phones | SST-GSM | SST-Dongle | 17 | 04-13-2006 10:17 |
x65 x75 v36+ new midlet px65v4 for flashing without testpoint!!! | ViperGSM | Siemens-Benq RingTones and WallPapers | 43 | 10-16-2005 22:07 |
Second Windows Vista Theme for your X65/X75 | [THE.ABYZZ] | S-Gold Based Phones | 0 | 08-15-2005 13:44 |
