| Dongle Problems (USB-Smart) Dongle probelms and installation support |
![]() ![]() ![]() ![]() ![]() Join Date: Sep 2000
Member: 2054 Status: Offline Thanks: 1
Maintenance SW very unstable
I have problems with Maintenance SW and sometimes with applications too. When I'm going to start Maintenance 4.0, in 50% of cases it won't really start (no window), but I can see it under running processes. The main problem is, that it is UNKILLABLE process, no way to stop (and restart) thread, even no way to restart PC normally, only a cold RESET helps. And if it starts OK, sometimes it freezes on clicking of buttons (for example "go support usb smart"), doesn't open IE window, doesn't answer, no way to stop and no way to get into support area until reset of the whole PC. I think it's protection issue but very annoying, please correct it. |
#2 | |
![]() ![]() ![]() ![]() Join Date: Feb 2005
Member: 115864 Status: Offline Thanks: 27
![]() ![]() ![]() ![]() Join Date: Mar 2004
Member: 60640 Status: Offline Thanks: 55
ITS TRUE Maintenane soft V4 Freeze Many Times , Cant Close
And The olnly solution for close are Restart the pc
Guest
Posts: n/a
Member: |
@ all who have this problem
Please tell me if you take out from usb port the dongle and try (after this) to close from Windows Task Manager the aplication is still remaning in proceses. Main problem is USB port, try to use an USB HUB and please report if you get same error. Best Regards, Manole |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2005
Member: 105625 Status: Offline Thanks: 9
When USB-smart software crashes/freezes (which is does pretty often
) software is completely frozen, and windows task manager is unable to end process. Your only hope is to remove dongle from USB-port.I think this should be fixed... In any case it should be possible to end the process normally from task manager if it freezes. Btw, i just got maintanance app freezing when clicking "update dongle smart card". |
#6 | |
Guest
Posts: n/a
Member: |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2002
Member: 17689 Status: Offline Sonork: 100.72392
yes even if we use USB HUB it hangs many many times somtimes dongle not found very unstable
![]() ![]() ![]() ![]() Join Date: Oct 2005
Member: 194949 Status: Offline Thanks: 0
With USB-Hub it is the same, only solution is to remove dongle and try again...
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2002
Member: 12660 Status: Offline Thanks: 3
In my experiance it happens sometimes just remove dongle then reinsert or I need to restart the machine either way its not a train smash in my eyes
WBR D. |
My PC is located under my desktop and very unconfortable to plug any dongle out of the USB ports located on the back panel.
I think a stable software would be the better solution than forcing users to change and (un)plug dongles and/or resetting their PCs becouse of a not killable thread. Manole/Zulea, please look for any satisfying solution! |
#11 | |
![]() ![]() ![]() ![]() Join Date: Jan 2002
Member: 8478 Status: Offline Thanks: 2
Guest
Posts: n/a
Member: |
For me is working very good directly to my usb or pluged into twister.
I cant help you more. BR, Manole |
