![]() ![]() Join Date: Apr 2006
Member: 254277 Status: Offline Thanks: 0
Aspicore GSM Tracker v1.13 S80 SymbianOS7 Cracked-SyMPDA
The product is intended for fleet tracking or personal location tracking. Would you like to...
Features Cost-effective and efficient tool to track several mobile phones in a remote SQL database. The client program runs in a Series 80 device, in the foreground or in the background. The program is able to connect to a Bluetooth GPS receiver and transmit the received GPS location data (NMEA-0183) to a central database via GPRS. You can configure the timers and events, which trigger the data send action. The data is sent in a compact UDP datagram, only a little over 100 GPRS bytes per message. This means that the data transfer costs are minimal compared to e.g. SMS. Location tracking system The central database can be a powerful SQL engine, which handles hundreds of mobile tracking targets. (Depending on the tracking frequency and resolution.) The database accumulates position data from the mobile phones being tracked. Each record in the database is identified by the IMEI code of the phone the data belongs to. The location data is collected to an industry standard SQL database. This makes it straightforward to integrate with the rest of your company data systems. How to evaluate? The central database solution is not included, but customers can use Aspicore''s test server in the Internet for evaluation and testing (http://www.toimii.com/gps). Server interface and tools Aspicore GSM Tracker sends data to the server as plain ASCII characters in an UDP datagram. You can write the receiving end program yourself by using UDP sockets, if you wish. NEW: You are free to use the sample Perl scripts or Java code to process the UDP datagrams and store them to a MySQL database. See Aspicore''s web site. Http is an alternative protocol for the UDP. Http data can be processed as shown in our PHP and ASP samples. There is a freeware Windows .NET PC utility to receive NMEA datagrams via UDP and send them to a standard GPS mapping program through a COM port. Aspicore Ltd is willing to provide you with the data collection database server software or to assist you to integrate the Aspicore GSM Tracker solution into your enterprise system. Refer to http://www.aspicore.com for a demo of smartphone real time location data integrated with Microsoft MapPoint .NET Web Service. Installation Copy the SIS file into your Series 80 device e.g. with a Bluetooth file transfer. Then you can use the "File manager" in your device to find acgsmtrckr80.SIS in the "Communicator/My files" folder. Open acgsmtrckr80.SIS. The installation should start. Delete the file acgsmtrckr80.SIS, when the installation has finished. There are alternative ways to install. You can use e.g. Nokia PC Suite or a MMC reader/writer. Supported phones Nokia 9300 and 9500 Supported GPS devices Any NMEA-0183 compliant Bluetooth GPS. Tested with
![]() downlink http://www.xxxpda.org/forum/showthread.php?t=268 |
| The Following User Says Thank You to Postive6630 For This Useful Post: |
