04-19-2006, 17:28 | #1 (permalink) |
No Life Poster Join Date: Jun 2000 Location: Germany Age: 49
Member: 1647 Status: Offline Thanks Meter: 4 | Error in reading flash or filesystem at K750i/D750i/W800 . I tried different CID36 phones. K750i, never touched D750i and converted W800i (former K750i) and tried an UC-10 cable and Fighter USB-Cable Used external voltage is 3.0Volt But everytime I try to read out the read-out-process starts up to 19% and after that stops. Phone hardware initialized OK Reading flash... Communication error. Continuing... Communication error. Continuing... Communication error. Continuing... Communication error. Continuing... Communication error. Continuing... Communication error. Continuing... Unable to recover from errors. Finished reading flash. Is there any solution or must we wait up to new cruiser-update which maybe fix it, if it is a general problem. I want to get D750i-filesystem just after flashing it, so it's a never started FS and AFAIK this is not possible to read out via filesystem-tab, right? There are no good files in support to rebrand a D750i to T-mobile splash, startups and themes. |
04-20-2006, 06:36 | #2 (permalink) | |
Major Poster Join Date: Dec 2004
Member: 102111 Status: Offline Thanks Meter: 0 | Quote:
I'm not sure whether the 'read ARM' option is now fully supported, if so you could read out the full flash and use it later on (just like some other tools do). | |
04-20-2006, 07:30 | #3 (permalink) |
Crazy Poster Join Date: May 2004
Member: 64757 Status: Offline Thanks Meter: 3 | Hi Tigerente, nice to see you here! Do you have the same problem with the converted W800? Did you start this phone before you tried to read out the FS? I have some backups here but only from unpacked FS. If you need the packed FS you should try to use the read ARM option as described by phoneman². BR Kai |
04-20-2006, 20:26 | #4 (permalink) | |
Member: 1647 Status: Offline Thanks Meter: 4 | Quote:
Yes, problem is with all versions while using the Read ARM/flash/fs-1/fs-2 tab. Indeed I can read out the unpacked filesystem, but can't rewrite it, because if read-out to fs-package, there are some files in .../bg_images/cache, which can't be written again to phone. How did you read out packed FS? I just want to have full FS-backups of T-Mobile and vodafone including the startups etc, which aren't in support area. And I don't want to go to my SP to ask again and again for a content refresh of a D750i or vodafone-K750i to get it complete back to delivery defaults. There must be a way to 'undo' a debranding or updating with the operator branded phones, not just to change back the CDA. The files in support sadly doesn't support the full content. | |
04-20-2006, 21:22 | #5 (permalink) | |
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | Quote:
There are still bugs (as you've found) with the reading RawFS contents. It's a lot better than it was in earlier versions but it's still not perfect. If you're going to be flashing operator brandings away from a phone you must tell your customer that there's currently no way of going back. I'm not sure how much sucess you'd have with other tools either, but I haven't tried so I can't comment. | |
05-31-2006, 19:27 | #6 (permalink) | |
Would be a nice feature, which helped me some time with older phones on whch the Cruiser was able to read out complete firmware. | |
NEW FLASH CHIP? ERROR IN READ. anycool t818 | KLiFFF | SpiderMan | 2 | 02-17-2009 11:10 |
Error in read gallery | kiricu | Typhoon Dongle | 5 | 11-23-2006 21:28 |
Language List to Flash of HWK for K750i,W550i,W800, where?¿I need to W800 Spanish | Grupo MovilFree | HWK | 5 | 01-03-2006 16:08 |
Need help with a t630....error in reading codes | nick90 | SonyEricsson (USB-Smart) | 18 | 11-19-2005 08:29 |
Readed flash file post at where???? | vin79 | SonyEricsson (USB-Smart) | 0 | 10-13-2005 11:35 |
