#46 | |
![]() Join Date: May 2006
Member: 284305 Status: Offline Thanks: 0
friend you need to remove 3 resistors v410 v411 v412 the three black resistors under the last 2 leds (keypad lights) if I know how to attach file I would send you a pic (100% works for me) yours Last edited by ali-jabbar; 06-02-2006 at 11:22. |
| The Following User Says Thank You to ali-jabbar For This Useful Post: |
#47 |
Member: 246947 Status: Offline Thanks: 0
hi, please i need all samsung codes for system failure/limited service, urgent please, thnx
#48 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2005
Member: 172434 Status: Offline Thanks: 1
Worked Fr me
Apply full eeprom code. *2767*3855#, if the problem remains, flash with latest version.
#49 |
Member: 166331 Status: Offline Thanks: 0
hi i have problem with p100 keypad not working don't you have solution for that
#50 |
Member: 199620 Status: Offline Thanks: 0
hi hope you can help me -i have a few e700 draining the battery-if changed charging block and pa -did software upgrade -still the same ?please help
#51 |
![]() Join Date: Apr 2003
Member: 26859 Status: Offline Thanks: 0
contact service on samsung e 300
I use a lot of datacable and soft but none works.
Can someone help me thanks |
#52 | |
![]() ![]() ![]() ![]() Join Date: Nov 2004
Member: 94762 Status: Offline Thanks: 100
-A200 -T100 -R210 use search botton to download [ Wray Victor + crack ] work 100% |
#53 |
Member: 54116 Status: Offline Thanks: 82
Plz Help I Have 2 E330 Work Good But Main Board Now Not Power On When I Connecte It To External Power It Signal That There Is Cour Cercuit That Mean That Voltage Be 0 After Connect Plz Help What I Have To Chane Or What I Have To Do To Power It Plz Plz Plz Help
| The Following User Says Thank You to SALIMUS For This Useful Post: |
#54 |
![]() Join Date: Apr 2006
Member: 257925 Status: Offline Thanks: 0
hi i have a samsung e330 its showing charging without conected to the charger.also when i switch it on it does not show the battry on display.the battry will only come after conecting to the charger.thats when it starts.discharging
please help assist with adiagram if possible thak u |
#55 |
hi i have a samsung e330 its showing charging without conected to the charger.what can i do
#56 |
Member: 24506 Status: Offline Thanks: 0
E600 brightness
Please help,cannot adjust brightness on internal lcd ,because no such option in the menu...The display is very dimm
#57 | |
![]() ![]() ![]() ![]() ![]() Join Date: Feb 2006
Member: 229987 Status: Offline Thanks: 109
#58 | |
#59 | |
#60 |
Member: 291897 Status: Offline Thanks: 0
Hi everyone... I'm new here and wondering if anyone can help me unlock my X700...I suspect it's stolen is there anyway to unlock it if so?
