![]() Join Date: Oct 2004
Member: 86516 Status: Offline Thanks: 0
Nokia 3650 error
When I switch on my mobile it loads up "normaly" to show up the wallpaper. As I press the any of the soft keys or menu buttons an error saying system error appears and returns back to stand by. I can make and recieve calls (cannot acess contacts), Fs calller works fine. But i cannot enter messaging, or any other program. If I continue pressing the menu button no applications are loaded where usualy there is one named telephone
If there is a way how to not format the phone and get it back to work ( at least untill I could make a backup of my contacts) Thanks for help in advance |
#2 | |
Member: 50848 Status: Offline Thanks: 7
second problem could be corrupted MMC (it happens when you unplug card reader without stopping it first and with defragmentation) there are some other files that can make problems.........e/system/libs.......and even on your phone memory....... for backing up your contacts you can remove mmc and start your phone to see if it`s working...... |
Allready tried removing the mmc but the same thing happens. can't arrive to the point of using fexplorer. When i press the menu button system error appears
well I fixed that problem only with formatin!
maybe it can help you to save contacts to sim card (if you can open contacts) but you will have to copy one by one |
can't open contacts neither.
I usualy use bluetooth to connect to my pc, but do you think if I buy a wire to connect to pc and use the nokia pc suite to make a backup would be possible? |
don`t think it`s possible....cable for 3650 is used for flashing only....
I can`t find another solution, sorry |
Thanks for your help
Super Moderator
![]() Join Date: Sep 2002
Member: 15312 Status: Offline Sonork: 100.1576041
Can´t he use BT and PC Suite? I think so...
BTW, try press Pencil key + power on. This skips all Apps on startup. Might help or not. |
The problem is i cannot connect using bluetooth as i cannot find a way to switch it on. Is there a way using somekind of code?
For the other tip of continue pressing the pencil button there is a problem as I made a lock code for phone, ie i have to release it and enter code. How can i remove the code? Thanks for help drug store, if you have any suggestions i would appriciate |
| The Following User Says Thank You to Osamabinlad For This Useful Post: |
Member: 390191 Status: Offline Thanks: 15
i have a problem bluetooth system error , i will do hard reset in my mobile ,but no result , so anybudy help me to solved this problem thanks this is my mail pluse send it tanvirkst@yahoo.com
