![]() ![]() ![]() ![]() Join Date: May 2005
Member: 144944 Status: Offline Thanks: 2
Nokia Useful & Fun Codes !!!
#PW+1234567890+1# = GIVES PROVIDER-LOCK STATUS #PW+1234567890+2# = GIVES NETWORK-LOCK STATUS #PW+1234567890+3# = GIVES COUNTRY-LOCK STATUS #PW+1234567890+4# = GIVES SIM-CARD-LOCK STATUS. *#0000# Displays your phones software version: 1st Line : Software Version 2nd Line : Software Release Date 3rd Line : Compression Type *#06# For checking the International Mobile Equipment Identity (IMEI Number) *#2640# Displays security code in use *#0000# Display Software ver. and compresion type *#100# Shows the phones number *#639# Programming - min/sid *#67705646# Removes operator logo on 3310 & 3330 *#73# Reset phone timers and game scores *#7760# Manufactures code *#7780# Restore factory settings *#92702689# Displays: 1. Serial Number 2. Date Made 3. Purchase Date 4. Date of last repair (0000 for no repairs) 5. Transfer User Data. To exit this mode you need to switch your phone off then on again *#30# Lets you see the private number *#94870345123456789# Deactivate the PWM-Mem (not recommend) *#746025625# Displays the Sim Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible **21*number# Turn on "All Calls" diverting to the phone number entered **61*number# Turn on "No Reply" diverting to the phone number entered **67*number# Turn on "On Busy" diverting to the phone number entered *3001#12345# Programming / Field Test *#21# Allows you to check the number that "All Calls" are diverted to *#61# Allows you to check the number that "On No Reply" calls are diverted to *#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to *#67# Allows you to check the number that "On Busy Calls" are diverted to *#43# Allows you to check the "Call Waiting" status of your phone. #3370# Enable Enhanced Full Rate Codec (EFR) #4720# Disable Half Rate Codec (correct code) *#1345# Shows credit value |
![]() ![]() ![]() Join Date: Oct 2005
Member: 191146 Status: Offline Thanks: 0
Very Nice
hai it very nice idea to the this tips for every body it very usefull to all
Member: 232783 Status: Offline Thanks: 0
Gr8 post man...
Keep up the gud work Regards, svjazz |
![]() ![]() ![]() ![]() Join Date: Mar 2005
Member: 127823 Status: Offline Thanks: 0
Wow! Thanks, I really found these usefull...
![]() ![]() Join Date: Dec 2005
Member: 209107 Status: Offline Thanks: 0
Do u have codes that for Three on noki@6630 to all it to allow it to use any sim
re!
You must unlock it! It's not for free at this time, sorry.
ps - look at "bb5" subforum for more information |
Member: 14297 Status: Offline Thanks: 0
#PW+1234567890+1# = GIVES PROVIDER-LOCK STATUS #PW+1234567890+2# = GIVES NETWORK-LOCK STATUS #PW+1234567890+3# = GIVES COUNTRY-LOCK STATUS #PW+1234567890+4# = GIVES SIM-CARD-LOCK STATUS. !!!!!WARNING!!!!! DO NOT ENTER THESE IF YOUR PHONE IS LOCKED TO A NETWORK!!!! YOU ONLY GET 5 TRYS THEN UR PHONE WILL NOT UNLOCK WITH IMEI CALC U WILL NEED A CABLE UNLOCKIN. THIS INC BB5 AS THE NEXTWORK PROVIDERS CAN PROVIDE CODES AT A FEE. sorry for caps but u need to understand this |
#8 | |
Member: 106049 Status: Offline Thanks: 2
Regards, Fonefusion |
For Nokia DCT-L (9110, 9210i, 9210 Etc)
Software Version : At Main Out Side Display *#0000# or *#682371158412125# Prodect Date : *#3283# For Hard Reset For Nokia DCT-L (9110, 9210i, 9210 Etc) Eject Battery and Reinsert Battery and Before Nokia Hands Appear Press : Ctrl + Shift + F ... this will ask u Confirmation about Formation, Press YES by push top right LCD Button ... A Processing Bar Appear and Complete Your Phone And Make As Fresh And Kool ! Njoy! Regards ~MahiL~ |
Sorry Due To Some Problem With My PC! i posted two times my POST! SOrry AGain !
#12 | |
-= GSM Network Service Codes =-
Here is the list :
Some of these may not work. When various network functions are selected via the cellphone's menu using the keypad, the cellphone automatically generates the corresponding GSM network command string and transmits it to the network. These commands can however be manually entered via the keypad. Each command is prefixed with either one or two * or # characters as follows: ** register and activate * activate ## de-register (Deactivate) # deactivate *# check status Once each command has been entered, if it is a network command it must be transmitted to the network by pressing Send key which acts as an enter key. Enter numbers in full international format +CountryAreaNumber. Command Description Command String: Security: Change call barring code **03*OldCode*NewCode*NewCode#SEND Change call barring code **03*330*OldCode*NewCode*NewCode#SEND Change PIN code **04*OldPIN*NewPIN*NewPIN#SEND Change PIN2 code **042*OldPIN2*NewPIN2*NewPIN2#SEND Unlock PIN code (when PIN is entered wrong 3 times) **05*PUK*NewPIN*NewPIN#SEND Unlock PIN2 code (when PIN2 is entered wrong 3 times) **052*PUK2*NewPIN2*NewPIN2#SEND Display IMEI *#06# Call Forwarding: (Diverting) De-register all call diversions ##002#SEND Set all configured call diversions to number and activate **004*number#SEND De-register all configured call diversions (no answer, not reachable, or busy) ##004#SEND Unconditionally divert all calls to number and activate **21*number#SEND Activate unconditionally divert all calls *21#SEND De-register unconditionally divert all calls ##21#SEND Deactivate unconditionally divert all calls #21#SEND Check status of unconditionally divert all calls *#21#SEND Divert on no answer to number and activate **61*number#SEND Activate divert on no answer *61#SEND De-register divert on no answer ##61#SEND Deactivate divert on no answer #61#SEND Check status of divert on no answer *#61#SEND Divert on not reachable to number and activate **62*number#SEND Activate divert on not reachable *62#SEND De-register divert on not reachable ##62#SEND Deactivate divert on not reachable #62#SEND Check status of divert on not reachable *#62#SEND Divert on busy to number and activate /td> **67*number#SEND< Activate divert on busy *67#SEND De-register divert on busy ##67#SEND Deactivate divert on busy #67#SEND Check status of divert on busy *#67#SEND Change number of seconds of ringing for the given service before diverting a call. Seconds must be a value from 5 to 30. De-registering the same divert will also delete this change. **service*number**seconds#SEND Call barring: Activate barr all outgoing calls (see Security to set code) **33*code#SEND Deactivate barr all outgoing calls #33*code#SEND Check status of barr all outgoing calls *#33#SEND Activate barr all calls **330*code#SEND Deactivate barr all calls #330*code#SEND Check status of barr all calls /td> *#330*code#SEND< Activate barr all outgoing international calls **331*code#SEND Deactivate barr all outgoing international calls #331*code#SEND Check status of barr all outgoing international calls *#331#SEND Activate barr all outgoing international calls except to home country **332*code#SEND Deactivate barr all outgoing international calls except to home country #332*code#SEND Check status of barr all outgoing international calls except to home country *#332#SEND Activate barr all outgoing calls **333*code#SEND Deactivate barr all outgoing calls #333*code#SEND Check status of barr all outgoing calls *#333#SEND Activate barr all incoming calls **35*code#SEND Deactivate barr all incoming calls #35*code#SEND Check status of barr all incoming calls *#35#SEND Activate barr all incoming calls when roaming **351*code#SEND Deactivate barr all incoming calls when roaming #351*code#SEND Check status of barr all incoming calls when roaming *#351#SEND Activate barr all incoming calls **353*code#SEND Deactivate barr all incoming calls #353*code#SEND Check status of barr all incoming calls *#353#SEND Call waiting: Activate call waiting *43*#SEND Deactivate call waiting /td> #43##SEND< Check status of call waiting *#43#SEND Calling Line Identification: The following only works if CLIP and CLIR are enabled: CLIP: Presentation of the number of the incoming call Activate CLIP **30#SEND Deactivate CLIP ##30#SEND Check status of CLIP *#30#SEND CLIR: Presentation of one's own number to the to the called party Activate CLIR **31#SEND Activate CLIR for the actual call *31#numberSEND Deactivate CLIR ##31#SEND Deactivate CLIR for the actual call #31#numberSEND Check status of CLIR *#31#SEND COLP: Presentation of the actual number reached (if number called was diverted to another number Activate COLP *76#SEND Deactivate COLP #76#SEND Check status of COLP *#76#SEND COLR: Presentation of the original number called by the calling party (if the call was diverted to this cellphone) Activate COLR *77#SEND Deactivate COLR #77#SEND Check status of COLR *#77#SEND GSM Network Service Codes: Note: That at present only the following service codes are in use: 11 Speech 13 fax 25 data In the future we will be able to control our individual calls by using of the following service codes. To do this the user has to insert the service code in front of the last # in the MMI command above. For example the sequence *21*number*16# would divert all SMS calls to the given number. Cellphone services: 10 = All types of cellphone services 11 = Speech service 12 = Data service 13 = Fax 14 = Datex-J 15 = Teletex 16 = Short message service (SMS) 18 = All data services without SMS 19 = All cellphone services without SMS Carrier services: 20 = All services 21 = All asynchronous services 22 = All synchronous services 23 = 3.1kHz services 24 = Synchronous point-to-point connections including PAD's (all synchronous data services) 25 = Asynchronous point-to-point connections including PAD's (all asynchronous data services) 26 = Data packet sending including PAD's (all synchronous data packet services) 27 = Services with PAD-share 29 = Digital connection with 12kbps |
Member: 320696 Status: Offline Thanks: 0
hi this is very good
my mo is nokia 6600 pl give me quickoffice 2.3.6 unlock code |
![]() ![]() ![]() ![]() Join Date: Jun 2006
Member: 288491 Status: Offline Thanks: 0
dearsir
tanx for ur usefull codes |
