Member: 232783 Status: Offline Thanks: 0
Smartphoneware.Full.Screen.Caller.v3.04.S60.Symbia nOS.incl.Keygen-HSpda
[FONT=Times New Roman]Full Screen Caller allows you to see a big picture of a person when you are receiving a phone call if this person is stored in your contacts database! ![]() Do you want to see a person who is calling you more clearly and in details? Well, use "Full Screen Caller" and your wish will be satisfied! Full Screen Caller allows you to see a big picture of a person when you are receiving a phone call if this person is stored in your contacts database! How does it work: "Full screen caller" has two modes: picture mode and caller info mode. Depending on the selected mode "Full screen caller" will show either a photo associated with a corresponding contact or detailed information about the caller. When "Full screen caller" is turned on, it shows a big photo of a caller or caller info screen during a phone call. A picture can appear during incoming or/and outcoming calls. In picture mode "Full screen caller" tries to get the biggest picture from "Pictures" during a call. If there is no picture then the program will try to get a big picture from Contacts application. If there's no big picture in Contacts it tries to get a picture from "Pictures" for a group. If it doesn't find any it shows a thumbnail or default picture. In caller info mode "Full screen caller" gets information about a caller from contacts database and shows fields that you set in settings dialog. ![]() Main view: This is the main view of "Full Screen Caller". In this view you can find the following commands: Turn On/Off - with the help of this option you can activate and deactivate "Full Screen Caller"; Pictures - application pictures; Settings - application settings; ![]() Settings: In this dialog you can configure the following settings: General: Mode - depending on your choice "Full screen caller" will show a photo or caller info screen; Backlight - if this option is turned on backlight will be on when Full Screen Caller shows a picture during a call; Show on - defines wheather to show the screen during outcoming or incoming calls; Picture mode settings: Picture: Default image - defines a predefined picture or a thumbnail shown in the case when a picture is not found; Show phone icon - if this option is turned on an icon will be shown in the field "Phone number"; Show phone number - if this option is turned on phone number will be shown in the field "Phone number"; Label type - defines content of the second string; Font name - font for text; Big image: Big image layout: Full screen - the picture will be stretched to fit the dimensions of the screen. If a picture does not have the preffered proportions (176 x 187) then the longer side of it will be cut and the shorter one - stretched. For example: if the size of the picture is 640 x 480 the result size will be 249 x 187, thus the left and right sides of the picture will be cut by (249-176)/2 = 36 pixels; Fit screen - the picture will be compressed to 176 x 187; Opacity; Opacity color; Phone number color; Phone label color; Phone name color; Background color; Thumbnail: Thumbnail layout: Standard; Original size; Fit screen; Thumbnail phone number color; Thumbnail phone name color; Thumbnail phone label color; Thumbnail background color; Thumbnail border color; Other: Sort order - defines sort order for pictures in Picture dialog; Caller info mode settings: Caller info: Background color; Font name - font for text; Info strings: 5 info strings with different fields that can be received from a contact. Moreover, you can set a different color for each string; ![]() ![]() How to assign a big picture to the contact: To assign a picture to a person, a group or simply choose a default one open Pictures. You will see a dialog that has 3 pages: Contacts; Groups; Default; In this dialog you can perform the following operations with the pictures: Open - show big picture; Select picture - lets you choose any picture from image folder; From camera - lets you make a snapshot via camera; Default picture - assign predefined image; Delete (Hot key: Pen/Abc+ C) - remove picture; Update all contacts - retrieve all big pictures from contacts; Compatible devices: Nokia 3230, Nokia 6260, Nokia 6600, Nokia 6620, Nokia 6630, Nokia 6670, Nokia 6680/6681/6682, Nokia 7610, Nokia N70, Samsung SGH-D730, Panasonic X700, Panasonic X800 Could any one post this software... I need them Regards, svjazz |
| The Following User Says Thank You to svjazz For This Useful Post: |
Member: 280034 Status: Offline Thanks: 0
thank you and i will send thomething to you
| The Following User Says Thank You to hanonamatata For This Useful Post: |
Member: 251763 Status: Offline Thanks: 0
hey..
where the link.. Post it here for all to share can.. Thnks |
| The Following User Says Thank You to zhexun For This Useful Post: |
