Old 06-09-2006, 10:51   #1
prestwest
Member: 100282
6260 - camera program won't open
looking for some help...
my 6260 will no longer open the camera program. If I try to use it, it flashes up camera program and instantly closes itself.
can anyone tell me how I can download and re-install original camera program or an alternative for same?
I have video programs already (thank you drug-store) but can't take a still picture anymore. PS - it did work but I recently had the firmware updated by Nokia under warranty (can't now cause its out of warranty) and I think since then it doesn't work.
cheers!
Old 06-09-2006, 15:21   #2
glenntelecom
Member: 195513
cheers!
im sure its hardware,better open your phone and remove the camera and clean the connectors of your cam im sure its only bad contact thats causes the error.
Old 06-09-2006, 18:51   #3
Misjah
Misjah's Avatar
Member: 50848
it could be software error, if you installed eti camcorder or similar app!
to check if it`s software you will need to rename libs folder (on mmc) to any name,then restart phone and change back to libs....restart again....(this can also solve ``feature not supported`` error with camera recorder)
Old 06-09-2006, 23:10   #4
SRNOURI
SRNOURI's Avatar
Member: 29870
I agree with 'Misjah' ,it could be software problem too.In one case i solved such this problem -that appeared after upgarde- with format user area and then do full factory with ufs3 box.
I SUGGEST you to test this way too.
BR.
Old 05-17-2007, 14:16   #5
stanimir_13
Member: 38888
It is softwere problem! In my experience PM change with full good pm resolve the problem. Short PM is prefer
The Following User Says Thank You to stanimir_13 For This Useful Post:
Page generated in 0.10635 seconds with 7 queries
