Go Back   GSM-Forum > GSM Mobile Brands -Software Area- > Smart Phones & PDA/PALM Organizers > Windows Mobile Pocket PC(PPC)
Windows Mobile Pocket PC(PPC) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices
Old 06-13-2006, 21:56   #1
Own
Member: 5569
Unhappy charger SPV C500
@all
i need charger pinout for spv c500 [ i tried with moto V3 , it not work]how to do? or i need schematic of spv c500.
br all
Old 06-14-2006, 10:36   #2
Naresh
Registered User
Member: 68672
use USB-cable for charging (means u can charge ur handset using usb data cable with computer
regards
Naresh
Old 06-14-2006, 19:21   #3
Own
Member: 5569
i will try
Thanks. but i tried charging with charger pocket pc but not work , and i will try with it.and result you again.
Old 06-16-2006, 08:03   #4
Naresh
Registered User
Member: 68672
hi
first u should load Activesync
then connect ur handset with usb cable.
if it will show cable connected on handset's LCD
then connect u handset for minimum 2 hours with pc if ur hanset charged
then check 5volt pin in usb cable .
& change the pins in the ur charger (moto v3) for 5volt
NOTE
if not chaged with cable & donot show cable connected on LCD then check ur charging connector
i'm charging my c500 as i explain with usb cable
Enjoy good luck
Naresh
Old 06-16-2006, 20:03   #5
Own
Member: 5569
Unhappy may be phone not work
i tried many way but still not charge , i think my phone not work[charging]and i need schematic for spv c500 for fix it
Thank you for all infomation but i want the schematic
Old 06-16-2006, 20:25   #6
geosan1638
geosan1638's Avatar
Member: 5204
1 2 3 4 5
1 according to USB spec : +5 VDC
4 use a 50k rezistor to ground
5 GND -?- Pin 4 according to USB spec : GND
If i remember this is how i did a charger for c500 a while ago.If it will not work let me know
Old 06-16-2006, 20:39   #7
Own
Member: 5569
Talking YEHH pin 4 = good info.
@geosan1638
pin 4 it good info. [i want it so long time]
BIG thank you
ps: i will try tomorow and result you
Old 06-21-2006, 19:51   #8
Own
Member: 5569
Talking result
@geosan1638
i tested it work!
Old 07-12-2006, 14:30   #9
dominik
dominik's Avatar
Member: 5389
For me it works only for 15 sec and after orange light it start green light and not charging.
I made charger from V3 charger 50k OK charger gives 5.3v out.What am I doing wrong???
WBR
Old 07-12-2006, 15:58   #10
geosan1638
geosan1638's Avatar
Member: 5204
the charger must have about 5v AND 1A(amper) If not it will not charge .
WBR
Old 11-22-2006, 20:54   #11
pawns
Member: 389299
Which voltage C500 must have? 5.15 or 5.00 ?
Old 04-28-2007, 14:41   #12
usernome
usernome's Avatar
Member: 19723
Originally Posted by geosan1638 View Post
1 2 3 4 5
Can you be more specific please ?
Thanx !
Old 04-29-2007, 00:36   #13
tomthumb
Member: 483156
I'm having problems with car chargers for the c500. I bought two from ebay and they do not work, obviously the sellers are not aware that the c500 is very fussy when it comes to charging.
One seller even confirmed they definately worked on a c500 before I won his item. The chargers are fine when used to charger other mini usb devices but they do not charge the c500 due to the power/data stream.
Old 04-30-2007, 15:33   #14
geosan1638
geosan1638's Avatar
Member: 5204
Thanx !
what eles do you need to know?
Old 05-14-2007, 08:16   #15
usernome
usernome's Avatar
Member: 19723
A schematic ...
Thanx !
Page generated in 0.63215 seconds with 6 queries
